05 grill on 00 F250?
Old Dec 2, 2009 | 06:29 PM
BigBlue00's Avatar
I was wondering if anyone knew if the grill or headlights from a 05 and newer F250/350 would fit on my 00 250?
Old Dec 2, 2009 | 06:33 PM
che22879's Avatar
they do fit if you change the header panel, and get the wiring that goes with the new lights since they use a different bulb. I've seen it done.
Old Dec 2, 2009 | 06:36 PM
che22879's Avatar
here's a link of how its done
http://www.thedieselstop.com/forums/...9-04-a-217185/
Old Dec 2, 2009 | 06:39 PM
BigBlue00's Avatar
Wow that looks great, would you know anywhere I would be able to get the front grille ect.
Old Dec 2, 2009 | 06:43 PM
che22879's Avatar
where are you located?
Old Dec 2, 2009 | 08:09 PM
BigBlue00's Avatar
Boston, Ma
Old Dec 2, 2009 | 08:47 PM
che22879's Avatar
not out there. have you tried tasca?
Old Dec 2, 2009 | 10:23 PM
BigBlue00's Avatar
No I haven't is it tasca.com ? its kind of a sad story about how I came upon this truck. But there is a list in my mind of what I need to have done to it.
Such as-
-Exhaust
-Rims/ tires that will lift the truck up a few inches
-Body work getting rid of all the rust.
Old Dec 2, 2009 | 10:49 PM
Zaairman's Avatar
You can make the grill fit one of two ways... Way #1 is to cut off the bottom inch or so of the 2005 grill to make it fit. You can buy pre-cut grills on ebay. #2 is to put the entire 2005 front end on your truck, like I did. The headlights will fit, but you either need a new header panel or cut lots out of your existing header panel around the headlights. And yes, the headlight plugs are different for the 2005+ lights. Easy to fix though.
Old Dec 3, 2009 | 10:27 AM
BigBlue00's Avatar
So If I just got the 05 grill and hacked allot off the bottom would it be able to work or would I have to get everything? And if you can would you know what to type in on ebay to find the precut grill or maybe a link?
Old Dec 3, 2009 | 02:47 PM
BigBlue00's Avatar
Ok so I did a little research and found these on ebay. How hard is it to put on?
http://cgi.ebay.com/ebaymotors/05-07...Q5fAccessories
Old Dec 3, 2009 | 06:03 PM
Buxton91's Avatar
since you are going to be doing body work and repainting, i would suggest just getting the whole 05+ front clip.
Old Dec 3, 2009 | 07:21 PM
Zaairman's Avatar
Like 5 screws and 2 clips. My mother could do it.
Old Dec 3, 2009 | 11:23 PM
BigBlue00's Avatar
I would do the entire front clip, but I think it would be way to much money. Also I think I can just slowly upgrade everything. Like do the grill first then the head lights then bumper. But I have a huge push bar that goes across the entire front with 4 huge PIAA lights that covers up allot of the bumper so I think it would be pointless.
