PTM Mirrors Pics
Old Aug 12, 2009 | 08:22 PM
  #31
kankles747's Avatar
Mirror Cap Pic
i didnt even take mine apart...saved me time i think. i used krylon fusion dark red toreador and krylon top clear cloat and it matched perfectly
heres a pic
Old Aug 12, 2009 | 08:31 PM
  #32
grassmanfx4's Avatar
Man i cant wait to do this!!
Old Aug 12, 2009 | 08:33 PM
  #33
Dude that looks outstanding... well done.
Old Aug 12, 2009 | 08:57 PM
  #34
kankles747's Avatar
thanks guys, if you guys need any help just let me know and ill give you my $.02 on what i did and what to stay away from
Old Aug 12, 2009 | 09:15 PM
  #35
I am having trouble finding arizona beige (my truck color). I know where to get it online, but I am trying to avoid that.
Old Aug 12, 2009 | 09:24 PM
  #36
kankles747's Avatar
i went to the local pep boys and they have a book for the krylon spray cans just look at the inside of the driver door and remember the exterior paint code and in the book it details it out for you which can your Arizona Beige is...for example dark red toreador's code is JL so in their mag color JL was something like DSMF-373 and so then you find that on the shelf and buy it along with their top clear coat.
did that help?
Old Aug 12, 2009 | 09:27 PM
  #37
Shanks12's Avatar
looks excellent... how many coats of paint and what grit did you use...
or just any tips or things to stay away from... looks real good man
Old Aug 12, 2009 | 09:28 PM
  #38
It did. I know my code is AQ, so I might go check out Pep Boys tommorow since you had success there. Thanks man
Old Aug 12, 2009 | 09:34 PM
  #39
kankles747's Avatar
i did two coats base and 3 coats clear
1.tape everything off except for what you want
2.then i used 320 grit sand paper and smoothed it out
3.then used primer adhesive (1 coat)
4.then used 600 grit sand paper just so the base would stick real well
5.then 2 base coats
6.then 3 clear coats.
this is a really easy mod and makes the truck look a ton better.
i would stay away from everything but krylon, its the only thing that i seem matches really well IMO. some people say to start off with something like 60 or 80 grit sand paper but i just stuck with 320 and 600 it worked really well.
hope this helps
Old Aug 12, 2009 | 09:36 PM
  #40
kankles747's Avatar
yeah im almost positive i saw it at pep boys and its like 5.95 for a 5 oz can of 6.95 for a 11 oz can i think not sure but hell of a lot cheaper than 20-25 bucks online. im sure if they dont have it they can order it for you and it shouldnt cost any extra.
Old Aug 12, 2009 | 09:46 PM
  #41
kankles747's Avatar
you guys know what...i just went to check what cans i used so i wasnt misleading you guys and it was krylon that sucked haha my bad get dupli-color from pep boys thats the one i used i tried krylon and it sucked a di**...my apologies to everyone, but it is indeed it is dupli-color
Old Aug 12, 2009 | 10:02 PM
  #42
Shanks12's Avatar
okay good to know... i may try this soon as i get some free time... now I've never messed with using a clear after painting... what exactly does that affect? how shinny (for lack of a better term) or to take away dullness??
Old Aug 12, 2009 | 10:06 PM
  #43
kankles747's Avatar
well the dupli-color comes out pritty shinny i wouldnt call it dull by any means, but from my experiences with the clear coat it helps shine it up a little more make it loo more OEM and prolongs the life of the paint as in chipping and what not. i would highly recommend putting at last 2 clear coats i did three because that is just what i always do.
Old Aug 12, 2009 | 10:10 PM
  #44
Thanks for the help man
Old Aug 12, 2009 | 10:15 PM
  #45
Shanks12's Avatar
sounds good man... def does sharpen the look of the truck
