How do i remove emblems
Old Aug 1, 2009 | 10:40 AM
LOUS150's Avatar
i am obviously not a body and fender man i want to remove my fender and tailgate emblems to paint a different color but not sure how and dont want to mess my truck up. its an 05 screw any help would be appreciated thanks
Old Aug 1, 2009 | 10:43 AM
FX41's Avatar
Fishing line has worked in the past, but there are metal pegs in the emblems. Some have used heat guns, some have not. You shouldn't be worried about messing the paint up, just don't use anything tha could scratch it. 3M adhesive remover or goo gone should work pretty well for getting the residual adhesive off.
Old Aug 1, 2009 | 10:48 AM
LOUS150's Avatar
ok thanks i am assuming that the logos are just glued on
Old Aug 1, 2009 | 10:51 AM
there are nuts on the back side you'd need to get access to. You'd have to remove the plastic fender liner, and the access panel on the tailgate to get access to the back of the emblems, then once the nuts are removed then you can work on getting the adhesive to break loose.
Long story short its much easier to carefully tape everything off you dont want to paint.
Or you can look at getting an emblem overlay from patriotdecals.com
Here's a silver one i had on my silver truck before it was totaled.
Old Aug 1, 2009 | 10:52 AM
jdruzik's Avatar
The combination of a heat gun and fishing line really is the only to easily remove the fender emblems... It's not hard...
Old Aug 1, 2009 | 07:53 PM
IDNC76's Avatar
i just put on my 09 emblems today and let me tell you it was a PITA removing the glue.
I used a hair dryer , fishing line and goo off, which worked very well, but it took about 3 hours
my advice , is to just tape them off on the truck , i ve done it a few times and it has worked well for me
Old Aug 1, 2009 | 08:05 PM
IDNC76's Avatar
the 04-08's just use double sided tape
Old Aug 1, 2009 | 08:57 PM
05BlackFX4's Avatar
Fishing line/dental floss and hair dryer
3M adhesive remover works well for getting the glue residue off
Old Aug 1, 2009 | 09:23 PM
LOUS150's Avatar
Thanks for the help got the badges off easy now just wrestling the glue off, can i get 2 sided tape made for the badges
Old Aug 2, 2009 | 08:40 AM
LonestarROB's Avatar
Yeah. 3M double sided foam tape. They sell it at autozone for a few bucks for a roll that should cover 3-4 badges.
Old Aug 2, 2009 | 09:04 AM
LOUS150's Avatar
Originally Posted by lonestarrob
yeah. 3m double sided foam tape. They sell it at autozone for a few bucks for a roll that should cover 3-4 badges.
thanks back to auto zone i go
Old Aug 3, 2009 | 08:08 PM
05BlackFX4's Avatar
I would recommend 3M as well...make sure it is automotive double sided tape...I would use the stuff that is used on bumpers etc...most body shops will have it...autozone may not have the right kind
Old Aug 3, 2009 | 08:33 PM
They do. Got some for mine. Just waiting for emblems to get back from painter.
Old Aug 3, 2009 | 09:53 PM
LoneRanger93's Avatar
If you have alot of residue left behind from taking the emblems off get yourself an eraser wheel, I used it to remove the tape left behind from a set of hood scoops and it took about 5 minutes after I spent 45 minutes trying to get it off by hand with goo gone and all that other crap. They just fit into any drill and are def worth the money, less than 10 bucks if I recall.
Old Aug 3, 2009 | 10:04 PM
AntzFreshWhip's Avatar
i had removed emblems on my previous truck. and i used gasoline to remove the 3m tape residue it worked like a charm. put a teaspoon on a rag and work it in. it comes off pretty easy. then afterward i washed off the gas then waxed the spot and all..
