Some Recent Updates I thought I'd share!
Old Mar 19, 2010 | 01:01 PM
  #241
animated_zombie's Avatar
Originally Posted by Dinggus
I need new brakes and rotors as well, hopefully you get it fixed soon.
Thanks.
When I get it all working I'll post the final part numbers, so if anybody wants to copy my setup they'll know exactly what to get and they won't have this runaround of parts...
Originally Posted by bigmoney
I got Deceticon for my f150 like 6 months ago from this website look great!!
http://www.webxtremes.com/transformersdecals.htm
I'm not quite sure why you posted this, but k...
Good job I guess...
I got mine from Patriot.
Old Mar 19, 2010 | 01:39 PM
  #242
FlashmasterK's Avatar
To remove the hub, you will have to get it pressed off, prob at a machine shop and then get the new ones pressed on = $ and pain in the a$$
If tirerack has ones that are already pressed together, just get those and call it a day. Cheaper in the long run.
I have also heard that alot of people are having problems with them warping. IMO, the slotted rotors dont add all that much unless you are going to be towing alot. But hell if they dont look good
Old Mar 19, 2010 | 01:49 PM
  #243
I'm hoping that they have some already pressed. I hope that's what they are sending me. As far as the slotted part, yeah I got them for the looks; with my 4.2 there's now way that I'll be towing anything.
We'll see what happens when I get the box...
Old Mar 19, 2010 | 03:04 PM
  #244
I've got the same engine and the rotors are difficult to find. Let me know how you like yours
A couple of weeks back I was going to swap them out cuz they were warped pretty badly, and I was going to go with the slotted or drilled. But it was difficult to find ones for our trucks so I just got them turned.
FYI- they have to be turned ON the truck, for future reference. Imagine how fun it was to take it all apart and drive around with your rotors in the back looking for a place to do it, just to figure out that you did all the work for nothing b/c they have to be on the truck to turn.
Old Mar 20, 2010 | 12:55 AM
  #245
Brutal...
Good to know though, thanks!
Actually I was going to turn them but the dealer told me that they were too warped to turn. And you figure if anyone wants to take your money then it's them, so I gotta figure it can't be done.
I plan on turning the backs though, once the fronts are done.
Old Mar 20, 2010 | 01:08 AM
  #246
Dinggus's Avatar
What is meant by turning them?
Old Mar 20, 2010 | 01:24 AM
  #247
Dinggus,
are you asking me or Flash?
If you are asking me, I can give you the PT# for the Pads,
but I haven't gotten the right rotors in yet,
so I don't have those part numbers yet.
Hawk HPS Brake Pads
Old Mar 20, 2010 | 01:27 AM
  #248
Dinggus's Avatar
Either you or him, I don't know what it means by turning them.
Old Mar 20, 2010 | 01:43 AM
  #249
Turning rotors is a process in which the rotors are evenly grinded down on both sides in order to true them. If your rotors are warped, it's usually much cheaper to "turn" them than it is to buy new rotors.
Video: Turning Rotors (You Tube)
Hope that answers your question.
Now, how you do that on a truck is beyond me...
Old Mar 20, 2010 | 02:07 AM
  #250
Dinggus's Avatar
Alright, yeah I was looking at rotor's and they are expensive. How do you know if your rotors are bad? I'm assuming my brakes are bad since I've never changed them since I've had the truck, ha.
Old Mar 20, 2010 | 03:07 AM
  #251
My brake pedal pluses like crazy when I push down on it.
That usually means warped rotors. A metal on metal sound
usually means that you need new pads. My pads are fine,
but I just figured I might as well upgrade while I'm in there.
Hope that helped
Old Mar 20, 2010 | 11:10 AM
  #252
Dinggus's Avatar
I was just curious, because when I hit my brakes from going fast, my truck shakes. Now I have to find a shop to unwarp them.
Old Mar 20, 2010 | 03:55 PM
  #253
Yeah, that sounds like warpage. If your lucky, they will be able to turn them.
Mine are too warped to turn safely. Basically if they were to turn them, they
would have to take so much off, that they wouldn't be safe any longer.
Hence why I'm having to replace them. Hopefully you'll be lucky and
will be able to get away with just turning them.
Old Mar 20, 2010 | 04:13 PM
  #254
Dinggus's Avatar
I think I'll have to replace them as well. Because they haven't been replaced since I've had the truck, and doubt they've been replaced when the previous owner had it. So that's 7 year old brakes and rotors. When I take the truck to the shop, I'll have them check out the brakes and rotors. I adjusted the tirerack for the brake pads for my truck, about $80 per set for brakes.
Old Mar 20, 2010 | 04:43 PM
  #255
Good stuff, your truck should be cheaper than mine as far as parts go.
Let me know what you end up getting, I pass it onto my Dad. Maybe
he'll use it on his '02.
