Getting primer overspray off my truck
Hi just wondering your guys opinions on a good product to get some primer overspray off my new truck. I just got home from college and washed my tuck the other day. It looked like there were all kinds of little dust particles on the hood and roof, well it turns out the dumf**k neighboor was spraying some parts for his car when it was gusting out and my truck happened to be staight downwind of his paint booth setup. To be honest I'm just as pissed at myself for leaving my rig in the back but I figured there was enough common sense there to not paint when it was blowing 25-30. My dad has a buffer but not sure what the right compound would be. Any advice much appreciated.
Thanks,
Zane
Thanks,
Zane
I drove over paint before , DId nt know it at first or that it was paint, it was all the way accross the road. It dried before i could go to wash it, i used bug a tar remover on it then a pressure washer and it came off the paint, wheelwells, tires. The washed a waxed with. I tried claybar, it took some off .
I've had cars and trucks completely covered in primer overspray, base coat overspray, and even clearcoat overspray. I've never found any that a good quality claybar could not get off.
A cool dry area works best. I used straight water which some will say doesn't work but has always worked perfect for me. If you spray a soap solution on it, sometimes the soap will not allow the clay to get to or penetrate the overspray enough and will more or less just slide right over it. Using purified or bottled water straight outta the bottle with claybar works very well.
Thanks for the advice guys I got the mothes claybar and it took it off fairly well, I'll have to go over it another time to cover the areas I missed but overall it looks great
Thanks again!
Zane
Thanks again!
Zane
Try using a clay bar and see if it can still be removed. If not, I guess your next option would be to have your paint buffed or polished.
Jeep Parts
Jeep Parts
