Anything relating to HID
Old Jan 26, 2009 | 04:55 PM
  #106
XenonLink's Avatar
Hi Guys, our buy 1, post review and get 1 free promo has ended. 5 customers has already took advantage of this offer. Please call me at 866-857-0005 if you are interested in buying. I would be able to give you some discounts over the phone only.
Old Jan 28, 2009 | 05:08 AM
  #107
freekyFX4's Avatar
I am still thinking about doing HIDs. I really like the idea of the bi-xenons. I would hate to lose my high beams.
Old Jan 28, 2009 | 07:41 PM
  #108
esf's Avatar
esf
I received my free kit today. I haven't opened it yet but I got it. I also wanted to say that these lights really shine in the snow. They're 6000k. I didn't know what to expect in the snow and I have to say I was impressed. Visibilty is much better than anything I've driven before.
Old Jan 29, 2009 | 03:11 PM
  #109
05_sprcrw's Avatar
X2
I love how much better they are in the snow! I can't say enough good things about HID's I will never own another vehicle with out them.
Old Jan 29, 2009 | 08:47 PM
  #110
XenonLink's Avatar
Even with Regular Hi/Lo kits you'll still have high beams. Just that your high beam would be in halogen bulb not HID. Only Bi-Xenon will let you have both high and low beam with HID.
Old Feb 3, 2009 | 05:13 PM
  #111
kxpaintball's Avatar
Need help and have some ????
I have a set of bi-xenon hid in my 08 f150 and in an 07 f150......Low beams work great but when you have the fog lights on and then try to use high beams the highs will not shut off..............But if you have the old bulb in the empty socket then everything works great. My question is can I buy a spare relay harness and plug it in on the empty socket for the driver bulb will this fix my problem. Next question is I have seen that the 07 and 08 f150 take the 9140 bulb for the fog lights but they only make a 9145 hid...some people have had problems with the housings for the fog light getting to hot is this the case and is there a fix.......
Old Feb 3, 2009 | 06:48 PM
  #112
XenonLink's Avatar
Can you tell me does your HID bulb comes with 2 wires or 3 wires connection?
We never had this issue with our Bi-Xenon HIDs.
Additional relay might help, but again I'm not sure because your HID is not ours.
9145 and 9140 both are the same. Its also known as H10.
Housing getting hot is normal. How hot are you talking about?
Old Feb 3, 2009 | 07:47 PM
  #113
2 or 3 wire are you talking about the hi beam connection? I think it is 2 wire it has been some time since I put them in.
Hot, I have heard of some mealting the housing
Old Feb 3, 2009 | 11:17 PM
  #114
ELVATO's Avatar
Have you done the fog mod? That seems take care of the problem you are describing. It's where you ground one of the pins in the fog relay.
Old Feb 4, 2009 | 06:33 AM
  #115
no I have not heard about a fog mod tell me more
Old Feb 4, 2009 | 04:58 PM
  #116
XenonLink's Avatar
If it's 2 wires I think that's your problem. Our Bi-Xenon has 3 wires. This third wire is connected directly to the factory connector. This is the signal connector which controls the on/off, switch to high beam/low beam.
I would say you'll need an additional relay for the other side of your headlight. But again I can't be sure if this will solve your problem since your HID kit is not our product.
Please let us know if the additional relay fixes the problem.
Regards to the melting of the housing. The HID bulb must be too close to the housing. Rule of thumb, there must be inch of distance from the tip of HID to the housing. If the tip of the HID is too close or touching the housing then it'll melt the housing. This should be the main cause for melting of the housing.
Old Feb 4, 2009 | 05:01 PM
  #117
05_sprcrw's Avatar
William,
Have you got the return package I sent yet?
Old Feb 4, 2009 | 05:05 PM
  #118
XenonLink's Avatar
Originally Posted by 05_sprcrw
William,
When did you send it in? Do you have the return #? I can go and check with our return dept.
Old Feb 4, 2009 | 05:07 PM
  #119
05_sprcrw's Avatar
The RMA is ST00003088
Old Feb 4, 2009 | 05:30 PM
  #120
XenonLink's Avatar
Ok, let me check if we've received the package.
