Anything relating to HID
Anyone having an issue with the relay harness? The relay is keeping my pass side headlight from lighting in high , works in low but i have to turn fogs on first for it to light up. I am calling Will today to run through it
got mine installed, work awesome except I have no high beams. i am hoping it is something with the jump wires. i am going to try to figure it out before i call. i don't know how i have driven without HID's all these years......
I will actually see the bulb move right? I can feel vibration in the motor, something is happening but i have no highs.
i did flip the diode already but the wire is next.
-----very much so far. great kit and customer service. i will be purchasing two kits to do some off road lights i have prob this summer.
ok kit installed, 6000k's look awesome! the kit was very easy with great directions.
my issue.....
i have a bi xenon kit. my hi's and lo's work great but my switch is backwards. hi's are my lo beam and lo's are my high beam. so low beam activates my high beam indicator light. i assume it is something in the diode but i tried different combinations. any input is appreciated.
ohh yes, 07 xlt, no jumper cables. just connect the cables.
my issue.....
my issue.....
my issue.....
The HID bulb moves up for high beam. The HID Bi-Xenon shouldn't move down for high beam. Check if this is your situation.
learn from my mistake!!!!!!
dont check your HID's in the day light. it is deceiving to what hi's and lo's are.
my kit is working flawlessly now! absolutely amazing. i will never run halogens again.
BUY FROM XENONLINK! I will be calling this summer to convert my off road lights.
