Painting 2004 Fogs.
Old Dec 10, 2008 | 08:16 PM
  #46
Originally Posted by NoLongerJeepin
Fogs turned out great Thanks for the write up
Now I have to decide to do it this way or just tint my fogs
Hows the light output?
You gotta paint them. The output has not changed at all noticeably. They look just as bright as before. I'll get some photos soon.
Old Dec 11, 2008 | 01:20 AM
  #47
SouthernStyle05's Avatar
i 2nd that... do em this way er your doin em wrong!!!
SouthernStyle
Old Mar 11, 2009 | 08:52 PM
  #48
Dredging up an oldie. :o
I just scored some fogs in the classifieds and will be painting them before I install them. How long do I have to cook them in the oven for in order to separate the lenses from the covers??
Old Mar 16, 2009 | 02:50 AM
  #49
not long, the fogs pop apart pretty easy!!! like 5 mins max i'd say and you should be able to get em apart em.
way way easier than the headlights!!!
just remember, DO NOT smoosh the tape down onto the part you want to keep chrome, just barely lay it on there.
goot luck stealth, been waitin on you to get this done!
post pics asap
SouthernStyle,
Old Mar 16, 2009 | 07:58 AM
  #50
Will do, it's going to look good.
I'm assuming the temp is ~250*?
Old Mar 16, 2009 | 10:22 AM
  #51
IDNC76's Avatar
i did the same as the headlights 250 for 10 min and they came apart very easily.
Old Mar 16, 2009 | 01:43 PM
  #52
All right. Thanks. The lights came in today.
So did you guys remove the bracket off the back of the housing before cooking them?
Old Mar 16, 2009 | 02:08 PM
  #53
IDNC76's Avatar
i didnt , last time i tried to remove the bracket off , i stripped a few screws and wound up using a dremel to take them off
Old Mar 16, 2009 | 02:10 PM
  #54
OK, first one is a cooking.
Old Mar 16, 2009 | 02:21 PM
  #55
Light #1 separated, too easy.
Light #2 in the oven.
Old Mar 16, 2009 | 02:34 PM
  #56
Light #2 separated. man, that was easy. The taping and painting will make up for it. I think I'll use paper for the majority of the masking and tape around the very edges.
Did any of you scuff up the chrome first?
Old Mar 16, 2009 | 03:17 PM
  #57
Also, what type of spray paint do you guys use to paint them? I believe I am going to go with gloss since I have HD heads, to match.
Old Mar 16, 2009 | 04:17 PM
  #58
OK, I was lightly wiping down the chrome since I washed the lights, that crap comes off if you look at it funny!
I'm going to have to be creative with the taping, that cheapo chrome has me worried.
Old Mar 16, 2009 | 04:32 PM
  #59
IDNC76's Avatar
yeah i remember wiping mine down with simple green or windex and if you rub hard enough the chrome comes off
Old Mar 16, 2009 | 09:06 PM
  #60
i know... im bout to just buy two more and do it again. i have had both of mine blow bulbs a couple time, there is a vent hole above the bulb and mine has had water drip down onto the bulbs and shatter them. then you gotta open em up again and do it all over. my chrome is really taking a beating.
its worth all the work though cuz they look super sharp when they are right.
good luck. waitin on pics
SouthernStyle
