Wanna see a $3500 bed upgrade?
Old May 27, 2008 | 03:52 PM
stealthster's Avatar
Patman03SprCrw, yes, I guess depending on what you would consider strong. They are rated for 75lbs of tools. I would not recommend using them as seats though.
Old May 27, 2008 | 04:22 PM
rednoved's Avatar
Originally Posted by stealthster
Thank you everyone for your comments. I did forget one more mod I plan to do, a power tailgate lock.
Anyway, south_ms_sprcru, the boxes are a little pricey, they were about $250 each, but for me, it's what I needed, something that would fit under the cover, be out of the way of the king pin, and be accessible.
JackandJanet, I believe you lose 8 x 8 for the canister at the front and an additional 4" - 5" when the cover is opened, in other words, the cover does not completely go back into the canopy, the key lock section will stay out. So, I would say about a foot, it would work for a 6 1/2 foot bed and a fifth wheel.
rednoved, yes, they are undercover boxes, you will love them. I did all of the installs myself except the Rhino Lining. For your undercover boxes, mount the column first, then put the box on and swing it almost closed, line up the latch, hold it, swing the box back and drill it. I replace the supplied self tapping bolts with all stainless steel hardware and tapped the holes. I think I may add LED surface mount lights and mount them on the roll cover canister for addition lighting. The Recon lighting looks very good, and provides very good lighting, but I want more on my hitch when needed, maybe a switched setup for the additional lights. As far as how I like everything so far, I love every choice I made, like I said, the cover, I don't think they make a better one, I may be wrong, but this thing will probably out live the truck. The swing cases are perfect for me. If you need more room though, they may lack in that area, but for me, they hold the tools I need with plenty of room to spare.
Hopefully I answered all of your questions, if I missed one, let me know.
Nope, you answered them all. Im glad I caught this thread, I hadn't seen anyone else show interest in that cover or boxes. I really like the cover, and the fact that it can support 500 pounds on top if someone got on it. I dont need a lot of space in a truck box, just room for jumper cables, tie downs, tow rope, few tools, jack relocation. small stuff like that. Thanks for replying, Im glad im not the only one now that saw these, i didnt know if i had a missed a "dont buy these products" memo. where do you have the switch for the bed lights mounted? You could mount a set of small fog lights in your bed, Im pretty sure the light output would be good!
Old May 27, 2008 | 04:37 PM
Shane1's Avatar
Those swing outs are bitch'n! Nice setup!
Old May 27, 2008 | 04:53 PM
scott1981's Avatar
Sweet set-up, I like how clean and organized everything is
Old May 27, 2008 | 05:10 PM
Lazarus's Avatar
Holy S%$t!! that is the best looking bed I have ever seen.
Those boxes are sweet!
Old May 27, 2008 | 05:12 PM
adfox77's Avatar
I have the same cover from Truck Cover USA and love it as well. Great looking truck
Old May 27, 2008 | 07:44 PM
rednoved, I was debating between several of the high end covers and I am very happy with my choice. Not saying the others are not any good, I am just happy with what I got for what I spent (hope that makes sense). Wanted to let you know their is one issue you may run into if you are getting the same boxes and cover. I mounted my hinges to my boxes about 1/2" higher then intended so that I could keep the factory tie downs (still had to flip the tie downs though). Anyway, the problem I ran into is that I could not mount the back rail mounts so I will have to come up with another method of clamping the back to mounts. You could actually get away with not clamping the back, but I am going to find a solution (small C clamp or something). Even if I would have mounted the boxes at the intended level, I believe the back mounts still would hit the top of the boxes. I was actually debating between the bed rug and Rhino myself, I ended up with the Rhino, but not for any particular reason. The bed rugs look very nice too. The boxes will hold what your looking for, because that's about what I have loaded, and I have the 20' 4 Gauge jumper cables from Sears (Big set). Also the boxes have a couple neat features that are not really mentioned in their ads. They have a release mechanism that ejects the box from the side toward the back. When closed, the boxes cannot be removed, so if the tailgate is locked, they are not coming out and walking away. If the tailgate is off or down, they can be pad locked to prevent theft.
Everyone else, thanks again for all of your positive comments.
Old May 27, 2008 | 07:55 PM
rednoved's Avatar
thanks! im really excited about getting them now.
Old May 27, 2008 | 07:56 PM
FX4life's Avatar
Nice!! Now im goin to have to get me some of them boxes...
Old May 27, 2008 | 07:59 PM
Hash278's Avatar
Thats awesome.....
rednoved's Avatar
Where did yall get your bed covers from?
Truck boxes?
Old May 27, 2008 | 10:28 PM
Despite the poor reviews from Truckadons, I purchased the cover from them because the price was the best I could find. They were running a cover sale (10% off). I am pleased to say I had no problems, in fact, a very good experience with them. They contacted me to find out if I had the tailgate step and provided me with detailed tracking from the manufacturer to my terminal. The swingcases, I purchased from 4wheelonline because they had the best price I could find if you purchased the set.
Old May 27, 2008 | 11:21 PM
rednoved, forgot to say that the switch for the bed lights is one of my Aux switches in the dash. I wanted the ability to turn the lights on while driving. I may install a 2nd relayed circuit and switch that would allow a switch in the back.
Old May 27, 2008 | 11:52 PM
Raptor05121's Avatar
Nice. I like the bed lighting but I'm going to buy two long strips of them. I don't like how Recon "bunched" them together into clusters of 6....
Old May 28, 2008 | 06:03 PM
adfox77's Avatar
Truck boxes?
I got the cover from my local linex dealer who also happens to be my neighbor.
