Theft weakness?
Old May 13, 2008 | 03:23 PM
Blue150's Avatar
Theft weakness?
Is the only reason the 04-08 are so easy to get into and steal stuff the drivers side door lock? Or is there another weakness? Other than the obvious breaking of a window. Just punch in the lock and your golden? I am thinking of something along the lines of fixing this issue if it is.
I did not know where to put this, I apologize if it is in the wrong place.
Old May 13, 2008 | 03:28 PM
azmidget91's Avatar
people have put handles from the other side or rear on the drivers door
Old May 13, 2008 | 03:48 PM
Blue150's Avatar
Yes and I have thought about doing that but I really want to be able to use my key incase the battery dies or I lock my keys in it. I think I have a way around this issue but I don't want to work on it just to find out that something else is just as easy.
Old May 13, 2008 | 05:56 PM
JackandJanet's Avatar
The way I understand it, someone can just stick a screwdriver between the blastic bucket part of the door handle and the sheet metal of the door itself. The screwdriver can then easily force the door lock open. This is true of ALL 4 doors, not just the driver's door. You can do the same thing with the tailgate, making it very easy to unlock and steal.
There were a few threads on thiis about 7-8 months ago. People were complaining that stuff had been stolen from their locked trucks and there was no evidence of break-in.
A solution is a plate you mount on the inside of the door (you have to take the trim off to do it). The plate is made by Jimmi Jammer and here's a webpage for their plates that fit Fords: http://www.trucksecurity.com/TScom%2...ase%20Ford.htm To protect everything, you need a set for the front doors, the rear doors if you have them and the tailgate. The plates protect the locks from a probing screwdriver.
I put these things in my truck one afternoon after I installed a GPS. I decided having a Gryphon programmer AND a GPS in it was just too much temptation. They're a little bit tricky to install, but nothing you can't figure out.
- Jack
Old May 14, 2008 | 07:26 AM
hivoltagefx4's Avatar
The sad fact is that if someone "wants" to break in, they will. I thought of the jimmi jammer as well, but I've heard that they are not fool proof either. I just make sure to remove my GPS and toss a towel over my dash to cover up my radio to hopefully detract thieves (even though it probably will not deter them) What to do, what to do??
Maybe I should get a vicious dog and have him live in my truck!
Old May 14, 2008 | 10:30 AM
Raptor05121's Avatar
Tint your windows so dark they cant peek inside
Old May 14, 2008 | 11:26 AM
A2SuperCrew's Avatar
I thought we had factory anti-theft? The screwdriver method doesn't trigger an alarm? Wow............ I guess that little red LED blinking on the dash doesn't count for much!
Old May 14, 2008 | 11:32 AM
I'm pretty sure the factory alarm will only go off if you open the door. That's why I went with a 2 way led Viper system.
Old May 14, 2008 | 12:58 PM
Blue150's Avatar
Maybe wire a door pin switch to 12V and the other end to some C4? LOL
Old May 14, 2008 | 12:59 PM
ELVATO's Avatar
I always thought that was just to say that the PATS system was working? And that only works if they try to start the truck.
I've always wondered how much laminating your windows would cost...
Old May 14, 2008 | 01:04 PM
kingfish51's Avatar
There is no factory alarm. The re light is for the pats system which will not allow a key other than the one programmed for your vehicle to start it.
Old May 14, 2008 | 01:13 PM
Not that an alarm will stop everybody, but I definitely would not rely on the factory alarm. Go with a 2 way system. At least that way you can be notified if someone is messing with your truck.
Old May 14, 2008 | 01:41 PM
Val3ntin0's Avatar
hivoltagefx4, which Viper alarm did you get? I've been looking into the Viper 5900 with remote start, and most likely adding a tilt sensor onto it.
Old May 14, 2008 | 01:45 PM
This is the exact system that I purchased. I love it!
Old May 14, 2008 | 02:38 PM
07redf150's Avatar
if you dont mind me askin, how much was yours?
