Fogs behind the grill
Old Jan 20, 2008 | 02:09 AM
  #61
chazf150's Avatar
Lucky 13 Thanks
Old Jan 20, 2008 | 11:00 PM
  #62
romanstine9's Avatar
i will be adding fogs behind the grill tomorrow afternoon... i purchased the lights tonight but the hardware stores were closed so i couldnt but the material to make the brackets. how should i go about making brackets?
Old Jan 21, 2008 | 02:31 AM
  #63
chazf150's Avatar
Go to the very first post and try coping the same set up. Couple 1" metal straps , nuts & bolt. Do a litte bending on a vise.
I used an L shaped metal strap and welded the 1" straps
1st time
2nd time had to do some modifying
Old Nov 27, 2008 | 05:51 AM
  #64
TommyRox's Avatar
So if I understand it - Home Depot has the parts to make the mountand it all bolts together - no welding etc...I love it !!!! Does anyone have the time that has done this to put together a small short but sweet diagram of this wonderful invention?
Old Nov 27, 2008 | 07:16 PM
  #65
Ronix's Avatar
I just bought flat bar from the depot and bent to fit how I wanted it.
You will want to paint it as the metal is not protected so it will rust. I will probably rebuild mine at some point. The flat bar although is anchored in the middle to help stop sway. When I redue mine I will use box bar or something stiffer for the horizontal piece as my lights to rattle a bit when on rough road.
Here's Mine
Old Nov 28, 2008 | 12:09 AM
  #66
TommyRox's Avatar
Sounds simple enough - thanks !! I was just looking at my grill and I have an 08 and I am not sure if it will let the light out...
Old Nov 28, 2008 | 01:11 AM
  #67
Lord Helmut's Avatar
They look good!
Old Mar 11, 2009 | 09:29 PM
  #68
ltz400racer's Avatar
hopefully doing this next week (spring break!!) ill post pics if people want to see it....
Old Mar 11, 2009 | 09:36 PM
  #69
i forgot to add, since i am a poor college student (lol) what is the cheapest lights you guys would recommend? preferably 6" round lights don't really care about brand, as lights are lights in my mind.
Old Mar 12, 2009 | 01:19 AM
  #70
Dozer_Guy's Avatar
man i wish i could rip the front of my 98 apart easily and do that...
Old Mar 14, 2009 | 05:54 PM
  #71
js04screw's Avatar
I have a fx2 grille waiting to be put in and was wondering if anyone has put driving lights behind one of those? Most of the pics are the honeycomb grille.
Or would the hella grille be a better option?
Old Mar 14, 2009 | 06:03 PM
  #72
blackedoutV6's Avatar
taking your grill off isnt that hard
Old Mar 14, 2009 | 06:17 PM
  #73
FX4life's Avatar
Everyone's lights look good I'm thinking ill switch my 400 series driving lights, to some of Hella's larger rally style lights one day..
Old Mar 14, 2009 | 10:26 PM
  #74
primerib's Avatar
Looks like the 04+ models can put some pretty big lights in there. I maxed out with 7" IPF driving lights because of the grill support.
Old Mar 25, 2009 | 11:10 PM
  #75
Talking Finally got around to doing it.
Well i finally got around to getting it done.. i think it looks pretty good. i took a different route (easier) than others.. lights are 100 watts 6", i think i might go bigger.. maybe 7" what do yall thinK?
lights behind grill...off
lights on (daytime)
little bit closer
my brackets
my way more angles
TOUCH switch...yes, you read it right, TOUCH!
off
on
different night shots...
wires are all soldered/ heat shrank together. its double fused (one between battery and relay, then one between the relay and switch).
next up... painting the heads black....
-LTZ
p.s. sorry if the pics are too big.. im not sure how to resize them, normal html coding (height="" width="") wouldnt work for me.
Last edited by ltz400racer; Mar 31, 2009 at 08:15 PM. Reason: added size of lights
