Replacement air dam / lower valance
Old Jan 10, 2001 | 05:01 PM
Jim A's Avatar
Cool Replacement air dam / lower valance
Found this air dam @ Stillen for $200 looks like Lightning but is the lower section only no full replacement cap. I plan to have mine painted Oxford White. According to Stillen they make this but Street Scene will be selling them also I think mabe it's the other way around but I really don't care it gives my truck the look I wanted.
Stillen Storm Air Dam
99 XLT SC Flareside, Oxford White, Sport, 4.6l, 275/60/17 tires, 3.55LS, 4 wheel discs/ABS, Ford bedliner, Downey SST Tonneau, K&N, Flowmaster II Dual out rear catback, Clear corners. Cerwin Vega Stealth 5x7 & Vega 5 1/4 componants using 4 x 100 watt amp. 8" 1408 Rockford sub in Qlogic sub box w/300w amp. Still using stock Premium Sound head unit. Street Scene grille painted black and Stillen Storm air dam with lights (unpainted for now).
[This message has been edited by Jim A (edited 01-10-2001).]
[This message has been edited by Jim A (edited 06-10-2001).]
Old Jan 10, 2001 | 05:36 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Cool
That was quick! ,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Stillen Quad light air dam, sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
Old Jan 10, 2001 | 10:32 PM
cooltrucks's Avatar
Post
thats cool looking.
i am going to be in the market for a new one in the spring. my stock one got damaged in my accidental off road i did. I like the looks of that one.
chuck
1999 XL, 2WD, standard cab, short bed, sport package, nascar package, bright red, V-6, 5 speed, Rockford Fosgate CD player, Pioneer 6x8. class 3 hitch, fog lights, Black Rhino Lining, K&N filter, General Grabber ST tires size p245/70/R16, Uniden Pro510xl cb, Extang Tuff Tonno 3. http://www.geocities.com/bassbuster/truck.html
I like to hang out at http://www.cooltrucks.net
Old Jan 11, 2001 | 02:48 AM
CR1's Avatar
CR1
Post
That would be cool if there were a billet grill for that opening also.
Old Jan 11, 2001 | 09:28 AM
Silver X's Avatar
Registered User
Post
There is a Billet Grill for it, and I think it might be the same as the L.
My truck at:
http://www.streetscenemag.com/ViewOw...?ProfileID=202
Old Jan 11, 2001 | 09:49 AM
mattadams's Avatar
Post
looks good! I'm going to be installing the PIAA front airdam for the 99-01 F-150/Expedition this weekend, Ill be sure to post some pics... It looks SHARP!
Old Jan 11, 2001 | 07:25 PM
Way2Big's Avatar
Talking
Matt,
I am considering doing the same thing on my '98 X by replacing the bumper with the 99+. My question to you is are you going to use the current foglight wiring to power the foglights of the new PIAA airdam? I can't wait to see a pic of your new airdam. Thanks!
'98 EB Expy 4x4
5.4L 3.73 LS
Trail.Tow & Skidplate Pkg.
DA MODS....
** Custom Fab. 4" Cold Air Enclosure
** Pro-M 80mm MAF w/Filter & SC cal.(Enclosed)
** WMS Velocity Tube
** 75mm Edelbrock/BBK TB
** Hand Ported TB/Intake Elbow
** Magnason/Eaton M90 Supercharger
** Mobil 1 Synthetic Filter & Oil
** Autometer Boost Gauge w/ A-pillar mounted pod
** Cust. Prog. Superchip
** JBA Jet Black Ceramic Coated Headers
** Stage 8 Locking Header Bolts
** "PROWLER" Tran's Oil Cooler w/ 10" Spal Cooling Fan
** Gibson Sweptside Catback
** IPD Rear Anti-Swaybar
** Bilstein Shocks
** Manik Grill/Brush and Rear Taillight Guards
** PIAA 520 Foglights
** Clear Corner Lens
** Stull Billet Grill and Bumper Insert
** Ford Molded Mud Guards
** Ford Hood Guard
** "EXPEDITION" Receiver Cover
COMING UP NEXT, IN THE FUTURE....
** Cobra Style Hood
** '99+ Front End W/PIAA Fog Light Air Dam Kit
** Brembo Front End Crossed Drilled Brake Kit w/ Matching Rear Rotors
** 18" Wheels, due to Brembos
"Its Sooo Big...Its Gotta to be Blown!"
Old Jan 11, 2001 | 10:02 PM
mattadams's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Way2Big:
Matt,
</font>
It is not recommended that you use the stock fog wiring for powering aftermarket lights, mainly because the stock fog lights are about 35 watts, and the lowest aftermarkets you will find are 55... it'll fry the wires BUT I am going to hook up the outside set of fog lights to the existing fog light switch so I'll still be able to turn on the 520 fog's the stock way instead of the PIAA switch (which is cool but I'd like to use the existing switch whenever possible, its already gone through the firewall! ), here's how I'll accomplish that...
You'd still have to use the PIAA harness and relay, then take the wire the goes from the relay to the switch (coming out of the relay in one direction you'd have the ground, then the wire going to the switch, then the wires going to the lights) and splice it into the fog factory fog light wiring. This way, it's still receiving the correct amount of power, still using the PIAA relay so you don't have to worry about frying any wiring, but just receiving the signal to be turned off or on from the main fog light switch! The only downside to this of course is that you couldn't have your brights and your fogs on at the same time, otherwise it would save bunches of time!
Old Jan 12, 2001 | 01:02 AM
Jim A's Avatar
Post
mattbert,
What ever happened to your group buy on PIAA lights. I'm not too happy with the lights in my new air dam, 55 watt but the lenses suck. I am thinking about the 510's because the openings are only 4-3/4 inches. Haven't decided whether to go driving lights or Ion fog. I live south of Los Angeles so the fogs make more sense but...
Jim A
Old Jan 12, 2001 | 06:37 AM
Way2Big's Avatar
Wink
Matt,
Duh, I should have thought of that difference in the wattage, but I will probably use your advice about the using the existing switch. I already have a set of 520 on the Manik grill guard so losing the other set when the Hi's are on will not be an issue.
Make sure to post pics when your done! Thanks!
'98 EB Expy 4x4
5.4L 3.73 LS
DA MODS....
** Mobil 1 Synthetic 0W-30 Oil & Filter
** Bilstein Shocks
** Ford Hood Guard
COMING UP THIS YEAR....
** AAD Cobra Style Hood
IN THE DISTANT FUTURE....
** Brembo Front End Crossed Drilled Brake Kit w/ Matching Crossed Drilled Rear Rotors
Old Jan 12, 2001 | 09:29 AM
mattadams's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Jim A:
mattbert,
Jim A
</font>
E-mail me at matt@explorerforum.com, it's still going on and I could probably get them to you within a few days if you wanted. They'd be right around $170-175 as I recall... Way2big, don't worry I'll post pics .
Old Jan 12, 2001 | 11:46 AM
Way2Big's Avatar
Question
Matt, what type of lights do you have in the airdam presently?
Old Jan 12, 2001 | 02:24 PM
mattadams's Avatar
Post
the stock fog lights and the stock airdam. Both will be for sale once the conversion is complete.
Old Jan 12, 2001 | 09:57 PM
mattadams's Avatar
Post
just thought I'd let you know, got the airdam installed tonight, some pics so far are here: http://bart.is-s.com/~explorers/madams/airdam/ I just finished it up to find out that I may have to re-do it tomorrow (pays to read hte instructions all the way through eh?) I'll let you know more details tomorrow.
Old Jan 18, 2001 | 06:57 PM
Stylin'SuperCrew's Avatar
Post
Jim,
Your air dam looks great. Does it hang lower that the stock air dam? I lowered my SuperCrew 2" in the front and want to make sure I won't take it out in a parking lot. Is there a matching grill inset available?
