Class D Amp Advice
Old Mar 28, 2008 | 11:24 AM
GrifN's Avatar
Class D Amp Advice
I'm in need of an amp to power 4 subs. The subs are 4-ohm dual voice coils, and require 250w RMS. I am okay with either 1 or 2 amps, but don't want 4 amps (for obvious reasons -- price and space). I was looking at the Alpine MRP-M500, and just getting 2 of them. However, I wouldn't be opposed to a single mono (must be class D though) which would provide 1000w RMS @ 1ohm. The obvious problem there is finding an amp that is stable at 1ohm -- this limits my choices.
The following are a few set-ups I could go with:
  • 1 mono amp, putting out 1000w RMS @ 1 Ohm
  • 2 mono amps, putting out 500w RMS @ 2 Ohms
  • 2 2-channel amps, putting out 250w RMS x 2 @ 4 Ohms
  • 1 4-channel amp, putting out 250w RMS x 4 @ 4 Ohms
Again, I want a Class D amp, because this is going in a daily driver, and I do make several-hour-long trips sometimes, and plan to have the subs blazing the whole way. I have taken a trip to UVA (from Atlanta, GA -- Georgia Tech) and back with no problems from my current Class D amp, and want to be able to keep that ability. So I want Class D just to be safe, which creates a little conflict when looking at multi-channel amps (because they are usually Class A/B). Do you guys have any amp recommendations? Any thoughts on the Alpine amp I listed above? Thanks for the help.
EDIT/NOTE: I'm not looking to spend millions of dollars on this amp either. Yes, I know there are some really nice amps out there, but I'd like something that is more of a most-bang-for-your-buck sort of amp.
Old Mar 28, 2008 | 01:08 PM
dirtyd88's Avatar
ithere is a mono amp you might want to check out. its a kicker 750.1, but kicker actually rates it at about 950 watts (dont know if that will be close enough to 1000 for you). there is a guy on ebay that has a store that sells a crap load of these. its a $500 amp that o got for $248 w/ shipping and everything else.
just a thought for you...
Old Mar 28, 2008 | 01:44 PM
GrifN's Avatar
Another thought I had -- would it be possible to get 1 2-channel amp that puts ou 500w x 2 @ 2 Ohms and just put 2 subs per channel (2 DVC4's wired in parallel would put out a 2-Ohm load)?
Old Mar 28, 2008 | 03:00 PM
jmt0645's Avatar
DVC4's
1 sub parrallel= 2ohm
2 subs parrallel= 1ohm
Old Mar 28, 2008 | 03:26 PM
GrifN's Avatar
Originally Posted by jmt0645
DVC4's
Hmm... We are both wrong.
1 DVC4 to a mono amp = 2 Ohms
2 DVC4's to a mono amp = 4 Ohms
But to answer my own question...
4 DVC4's to a 2-channel amp = 2 x 4 Ohms
Old Mar 28, 2008 | 04:02 PM
GrifN's Avatar
So... After spending more time at work not working, I decided to invest my time in looking into this and drawing it out (I work better with pictures). I used Crutchfield Advisor with help on this (they did most of the work).
Here are my choices (these set-ups/values are a per-channel basis and would supply each sub with 250w RMS):
Seems to me like the 2nd and 3rd options are the worst, being that it's a lot harder/more expensive to find an amp that can supply 500w RMS @ 4 Ohms. The 1st set-up seems like it would have the most choices, but I would have to buy 2 amps, which could make it more expensive than the 4th choice. That being said, I think I will probably be going with option 4. So can anyone recommend a mono Class D amp that'll run at 1000w RMS @ 2 Ohms?
Old Mar 28, 2008 | 04:05 PM
jmt0645's Avatar
no big deal but i wasn't wrong, i just gave you one option for 2 DVC4's. oh well.
Old Mar 28, 2008 | 04:10 PM
GrifN's Avatar
Haha, okay, fair enough. Man, I love work. I have been getting paid to sit on my bum all day.
Old Mar 28, 2008 | 04:37 PM
styxnpicks's Avatar
500w @ 4 ohms is ALOT more expensive than 500w @ 1 Ohm
Old Mar 28, 2008 | 04:40 PM
jmt0645's Avatar
lucky
Old Mar 29, 2008 | 12:50 AM
GrifN's Avatar
Yeah. I think I've decided on an amp. Since I love my current amp, I think I am going to go with another Kenwood -- the Kenwood Excelon KAC-X1R. Crutchfield has it listed for $500, but I know I can get it cheaper. It puts out 1200w RMS @ 2 Ohms, so I think that'll be more than sufficient for my subs. Plus, it's one of the shorter ones on the market at 13 5/16" long (which is important when it's going under a rear seat). Thoughts about this amp? Anyone heard anything good/bad about it? The reviews on Crutchfield seem to be pretty good (from what I remember, but maybe that was for a different amp).
Old Mar 31, 2008 | 10:15 PM
dB-SPL's Avatar
Okay.. Your final load options are .5-, 2-, or 8-Ohms with four DVC-4 drivers. Stick with a mono class D. Much more simple. Find any mono amp that will do a TRUE 1000wRMS @ 2-ohms. There's plenty. Or find an amp that is .5-Ohm stable with the supporting power. The 0.5-Ohm amp would be more efficient, but also take its toll on your electrical system. The 2-Ohm amps are usually cheaper and much more common. I'd suggest something along the lines of a Kicker ZX1000.1 or an Alpine MRP-1000.
Cheers!
