Amp Speaker Wires...New wires or factory?
Old Jan 6, 2008 | 03:51 PM
jhogan20's Avatar
I am hooking up a 4 channel amp for my door speakers. Should I run the speaker wire back up behind the dash and connect to the factory speaker wire or should I reroute new wire?
Old Jan 6, 2008 | 06:06 PM
2006M50B's Avatar
I would run speaker wire from the amp to the speakers
Old Jan 6, 2008 | 08:24 PM
scottbigred's Avatar
whats the rms rating of the amp? if its low enough for the factory wires to support then just run them to behind the h/u and save your self all the time and hassle.
Old Jan 6, 2008 | 08:40 PM
jhogan20's Avatar
50Watts RMS (Rockford Fosgate 400-4)
What is the max you should run through your factory speaker wire?
Old Jan 6, 2008 | 09:01 PM
not sure on a max but you should be just fine running that through your factory wires. and it saves lots of install time also
Old Jan 7, 2008 | 02:47 AM
Low_e_Red's Avatar
The highest i would go on Ford wire is 100-125. But it depends on the setup.
Old Jan 7, 2008 | 11:56 AM
Devildog101's Avatar
You should be fine running it throught the stock wiring...
Devildog101
Old Jan 7, 2008 | 11:58 AM
jhogan20's Avatar
cool thanks
