system renovation has begun
Old Feb 6, 2007 | 05:19 PM
jmt0645's Avatar
Talking system renovation has begun
Here is step 1
great stuff expanding foam
And a Husky pro 14 inch breaker bar and T-50 torx bit in preperation for step 2 ( interior removal ) in the morning
Old Feb 6, 2007 | 06:51 PM
Biteyahard's Avatar
I like the expanding foam idea, please explain the benefits. I'm assuming its for deadening? If so why not just use the dynamat, or is this in addition to that?
Old Feb 6, 2007 | 07:06 PM
jmt0645's Avatar
expanding foam fills in all the voids between the inner/outer panels on the back wall creating one "solid" panel, and yes the foam is just step 1 of many,
tommorow I plan on gutting the interior and dynamatting EVERY square inch of exposed metal surface, even the roof
Old Feb 6, 2007 | 07:21 PM
Biteyahard's Avatar
Cool, looking forward to following you as you go. I'm about to get rockin myself but it may be a week or so before I get started, I'll be working 15 hour days this next 8 days.
What brand and how much of the foam did you use? Also was that the only spot you used it?
Old Feb 6, 2007 | 07:59 PM
jmt0645's Avatar
the braND IS "GREAT STUFF" from home depot ~5 bucks a can, I'm puttin it in the back wall, a/b/c pillars so i got 12 cans. If my math is right 12 16once cans once expanded i should have about 1 1/2 cans left over! always get more than you think you might need
I'm also using Elemental Designs Edeadv1 sound deadener, I ordered 200 square FT at $0.80 a square foot. so far i have all 4 doors matted as well
as a few dash panels that would also vibrate any time the bass would HIT!
Old Feb 7, 2007 | 07:27 PM
Biteyahard's Avatar
Sorry dude I'm gonna be asking lots of questions, take it as a compliment.
Did you drill to get specific areas filled? Also don't you need exta "venting" so the foam has somewhere to puch the air? Forgive my ignorance but I am very interested in this process. Also, are there any negatives to this process?
Old Feb 7, 2007 | 07:43 PM
jmt0645's Avatar
feel free to ask as many ?'s as you want to!
1) no I did not need to drill any holes as there is alot already there.
2) no, the only venting needed is one window "cracked" or the door open when you are spraying the foam. No further venting is needed after the initial "spray"
3) the only "downside" to the foam is it is so d*mn sticky! if you can avoid getting it all over yourself unlike i did, you'll be good
and an update on progress, I took the interior out and matted the floor, roof, a/b/c pillars foamed and matted, will get you photos in the morning.
Old Feb 7, 2007 | 08:05 PM
Biteyahard's Avatar
As far as deadoner goes, is it personal preference or is one better than the rest by far? I see Dynamat, Fatmat, ED, etc. They seem to be pretty much the same stuff, or not?
Old Feb 7, 2007 | 09:08 PM
jmt0645's Avatar
the big 3 are dynamat/fattmatt/Edeadv1, they all are EXACTLY the same, the reason I chose ED is because it was $0.80 a square foot instead of ~ $1.20 with the other 2.
Old Feb 7, 2007 | 11:07 PM
SSpiro's Avatar
I also used edead.
Old Feb 8, 2007 | 09:35 AM
jmt0645's Avatar
photo time,
1) front
2) back floor
3) partially finished back wall
forgat to snap pic before I put the carpet back in, so imagine the floorpan has silver mat
on todays agenda, finish back wall, reinstall rear seat, paint 1/2 inch MDF amp mounts(will get pics when dry) rewire system.
Old Feb 8, 2007 | 10:15 AM
dconder's Avatar
Man, I wish I had that kind of time to gut the truck and do that. Keep it up. You are doing a great job. It has the makings of a great system and you are starting it off right.
Old Feb 8, 2007 | 02:02 PM
jmt0645's Avatar
thanks D. here are photos of the Capacitor and amp boards, believe me the paint job looks ALOT better in person as my "el cheapo" walmart camera doesn't do the House of Kolor Cobalt blue pearl justice
Brand new Kole audio 15 farad capacitor with volt and amp readings
and amp board awaiting Rockford amp to be delivered.
Old Feb 8, 2007 | 02:20 PM
cool cool, ill have to keep checking in on your progress
Old Feb 8, 2007 | 08:04 PM
Bartak1's Avatar
Looking good. Keep it up!
