system renovation has begun
Old Feb 8, 2007 | 09:41 PM
Biteyahard's Avatar
Originally Posted by jmt0645
the big 3 are dynamat/fattmatt/Edeadv1, they all are EXACTLY the same, the reason I chose ED is because it was $0.80 a square foot instead of ~ $1.20 with the other 2.
Yeah it makes sense to save a few bucks when you can especially when they are the same thing.
Nice new pix, I have a question though? I'm assuming this isn't your daily driver? I can't see myself doing this massive project while still being able to drive to work every day.
Old Feb 8, 2007 | 09:48 PM
jmt0645's Avatar
actually it is my daily driver/ tow vehicle, I was just lucky enough to be off the past 3 days
Old Feb 8, 2007 | 09:59 PM
Biteyahard's Avatar
Bastard, I need some days off so I can get started!
Old Feb 8, 2007 | 10:05 PM
jmt0645's Avatar
in all truthfulness, it only took 1 day to gut the interior and mat it
what took me so long is the backwall, waiting for the foam to fully expand and all
also, my math was dead on, I've got 1 can leftover
Old Feb 8, 2007 | 10:22 PM
Bartak1's Avatar
So where all did you put the expanding foam exactley?
Or did you put all of it on/in the back wall?
Old Feb 8, 2007 | 11:51 PM
John Scaro's Avatar
AWESOME job Justin
I will be adding great stuff to my list of supplies needed for my install! I can't wait to do this. Since the other day of scratching one of my MINT PPI amps, I decided to leave my system alone till I have everything I need. Thanks for the pictures of your progress, keep up the good work
Old Feb 9, 2007 | 04:34 AM
styxnpicks's Avatar
are you not rolling the mat one with a wallpaper seamer? it looks like your tying to stick it on by hand?
btw all sounddeadener is NOT created equal, fatmat ia crapmat and nowhere near the quality of say edead raammat or dynamat
www.sounddeadenershowdown.com
Old Feb 9, 2007 | 08:54 AM
Impact9's Avatar
Yea well too late for that. It's not horrible stuff but there is better. You do need to lay that on better. Those pockets of air under the mat will expand in the heat and make the deadening fall off. Take a knife and cut a small hole to push the air out of.
Old Feb 9, 2007 | 09:11 AM
jmt0645's Avatar
yeah, I used the roller on the mat, what your seeing is were i used the foam to create a flat surface on the back wall.I laid the mat on then sprayed foam in the air pockets behind it, so the back wall appears flat. instead of all the ridges. Its an appearance kind of thing, I know it may sound stupid, but thats what I wanted to do. To each there own you know.
And I "sit" corrected about the deadener being equal:o my bad
Old Feb 9, 2007 | 09:45 AM
styxnpicks's Avatar
ohh ok, thats cool with all the expanding foam, I know youve seen the one and only pic I got of my project with only the floor done, I drove it like that for a few weeks... I'd say it took about 2 months before I got everthing back in..... and even then I still need to get the rear seat back in
Old Feb 9, 2007 | 10:13 AM
jmt0645's Avatar
yeah man, your where I got the idea of the foam from, I just went a little further with it. Good idea BTW I plan on doin this with my next truck for sure. The SQ of my system is SOOOOO much better , and road noise almost 0 now!
Old Feb 9, 2007 | 10:41 AM
styxnpicks's Avatar
I'm glad someone else took the extra step, I keep telling everyone to stuff the c pillar and back wall with foam and then do about 3 layers of mat everywhere.... you would think they would want their truck to ride like a benz.... as if it wasnt quiet enuff.... it gets even quiter
Old Feb 9, 2007 | 04:47 PM
jmt0645's Avatar
d*mn right
Old Feb 9, 2007 | 04:50 PM
jmt0645's Avatar
Also I just put a 2awg wire from the frame/body to the battery, I gained a couple DB with just that. I'm at 125.6 with all my old jensen stuff when before all this it would only hit 110.2 (crappy) and SQ wasn't that great.
Old Feb 9, 2007 | 11:13 PM
styxnpicks's Avatar
every little bit helps,
I cant wait to replace my stock batt with my dual optimas wired up with 1/0
