2018 F150 swap 18 inch for 20 inch
Old 07-05-2018, 10:10 PM
hnettles's Avatar
I have myself a brand new 2018 XLT Supercrew, with the 18 inch chrome wheels. And I'm not really crazy about chrome wheels.
Looking on the local Craigslist, I find new take offs, 20 inch Ford wheels and tires, for around $1200. If I do this, will I need to have my speedometer re-calibrated, or does the diameter wind up about the same?
Yes, I could do some research, look up exactly what size tires I have, and excatly what size tires come in the factory 20 inch package, and use the calculator at Tire Rack, but hey, I'm lazy, and I'll bet others have already done the homework.
Old 07-06-2018, 12:02 AM
glc is offline
How do you expect us to tell you without knowing both tire sizes?
You know how to do it, don't be so lazy and expect us to do it all for you!
Old 07-06-2018, 08:09 AM
glc is right... don't be lazy.
Old 07-06-2018, 07:59 PM
Labnerd's Avatar
275/55/20 stock tires and wheels. 18's I have no idea.
Old 07-06-2018, 09:28 PM
tuckr2's Avatar
The 18’s are very likely 275/65/18. Both tires are very compatible in size/diameter and the swap of OEM wheels and tires will have no effect in the truck.
Old 07-06-2018, 09:59 PM
MitchF150's Avatar
I figure that since Ford put 20" wheels on the outside and chose to give me an 18" wheel spare, they must be pretty close to same overall dia... Which they are if you do the math..
Mitch
Old 07-11-2018, 11:06 PM
hnettles's Avatar
My tires are 265/60 R18. If the 20 inch Ford wheels and tires are indeed 275/55 R20, then the circumference goes from 30.5 inches to 31.9 inches, a difference of +4.6%.
So 70 mph indicated would be 73.22 mph. Would I want to pay for a recalibration based on that small of a difference? Hmmm….
Old 07-11-2018, 11:44 PM
glc is offline
Yes, because it would also affect the way it runs, transmission shift points, etc.
Old 07-14-2018, 11:38 PM
tuckr2's Avatar
Most Fords OEM tires are undersized compared to odometer readings. You can quickly find this out by checking your mileage using road mileage markers or good gps. My last 3 Fords the odometer was off almost 1/10 mile. By putting on slightly larger tire diameter the odometer reading is closer to corrected.
In any event going up an inch doesn’t warrant recalibration of the speedo.
Quick Reply: 2018 F150 swap 18 inch for 20 inch
