2015 3.5 Ecoboost redline
Old 02-07-2016, 01:20 PM
Coops15eco's Avatar
Hey everyone,
New to the site, seems like you guys have some useful answers to some questions other people have had, so I'd figure I'd try it out!
My question is, how much damage can actually be cause driving these at redline? I shift at WOT/redline maybe 5 times a week, usually when someone is feeling froggy, and wants to run em, just a quick spirt to about 80 is all I do. But the truck has 6500 hundred miles on it. Getting ready to change the oil in 2 days. It's stock, so I know if anything happens its covered under warranty, but I don't want the inconvenience!
Thanks for all responses!
(I hope I put this in the right thread lol)
Old 02-07-2016, 05:21 PM
JackandJanet's Avatar
Hi and welcome! Unless something changed in the 2015 model year, the truck's computer will keep you from revving the engine into a state that will cause damage, either to the engine itself or to the transmission.
Basically, it simply cuts spark and fuel when the engine reaches the max RPM setting. And, doesn't restore those things until the RPM drops back into the "safe" range.
If I've got this wrong, someone will be along quickly to correct me.
- Jack
Old 02-07-2016, 05:32 PM
crazynip's Avatar
LoL... how old are you?
I predict a "Ford voided my warranty" thread coming soon by this guy after he blows his engine
Old 02-07-2016, 05:33 PM
glc is offline
If you leave it in Drive, the transmission will shift at the optimum rpm, and there shouldn't be any damage. The computer is a lot smarter than a person.
Old 02-07-2016, 06:16 PM
Coops15eco's Avatar
Ford won't void the warranty. Unless it's intentional neglect.
Old 02-07-2016, 07:15 PM
thelariat02's Avatar
Which sounds like you are doing.
Old 02-07-2016, 07:44 PM
Coops15eco's Avatar
So driving at WOT a few times a week is neglect? Even when I change the oil and do all the other maintenance that I shouldl? Hmm, seems like you guys know what your talking about... So much for being part of a helpful forum...
Old 02-07-2016, 07:53 PM
It's a truck. Meant to tow big trailers and haul stuff. It's not a racecar, nor is it built for it. Will the engine hold up? Probably it's a pretty stout engine. Not letting it shift when it should by manually shifting and letting it redline is neglect, yes. I run my truck hard too, but won't blame Ford when it blows up.
Old 02-07-2016, 07:58 PM
Coops15eco's Avatar
Well in that case I do agree, but I also find that the manual shift is pointless when I have a tow/haul mode. I mean it even downshifts for you, I've never used the manual shift. Like the second or third post said, the computers are smarter than a human!
Old 02-07-2016, 09:23 PM
glc is offline
Then if you aren't manually shifting it, don't worry about redlining it. The computer won't let you.
Ignore those guys, you aren't neglecting or abusing it.
Old 02-07-2016, 09:29 PM
Coops15eco's Avatar
Thank you!
Old 02-08-2016, 09:52 AM
Wookie's Avatar
On a stock tune you can't over rev the engine, the PCM won't let you. Also consider, the 3.5 EcoBoost is a very close cousin to the base model 3.7L that has a redline of around 2K higher but the 3.5 has stouter internals. However, the real choke point is the factory turbos. Those little K03s can't pump enough air volume to feed the engine at really high RPMs. As a result the intake charge temps go up and power really doesn't increase.
Old 02-08-2016, 06:51 PM
bkool2323's Avatar
why would you want to 5 times a week? Is it that thrilling? Maybe it's a new type of sex.
Old 02-08-2016, 07:15 PM
Wookie's Avatar
Hey man, what you go putting up yer tailpipe ain't none of our business. The new rule is "Don't ask, we can tell".
Old 02-08-2016, 08:07 PM
Coops15eco's Avatar
40k+ for a truck. It's a lease, so if I wanna have a little sex with the skinny pedal, I can, my names on the registration. Lol
Quick Reply: 2015 3.5 Ecoboost redline
