Bad shake/shutter
Bad shake/shutter
Alright guys.. so. I have a 2012 f150 with a 6 inch lift and 24x14x35 wheels/tires. My truck had a shake/shutter before putting these wheels on, and I bought new ones because my last set of 35’s were junk and wouldn’t balance so I figured that was the problem. Well, it still does it. Feels like the front end is about to fall off, so I don’t think it’s the wheels. I worked at a ford dealership and no mechanic knew or found anything lose. Do you guys have any idea why it does it and gets better and worse on and off? It’s worse at highway speed and when you turn the wheel it’s worse. Been having this problem for over a year and can’t find anything. Do I need to upgrade anything ? I have no clue. Does anyone here have the same or similar setup and how does your truck ride?
I'm late to the game, but for future reference for anyone observing this post, the owner's manual states that any modification to the vehicle that involves changing the angle of the driveline can (and likely will) cause shuttering. So lift kits will likely be the issue.
Though this might be from the factory service manual under diagnostics, I can't remember.
