2010 F150 FX4 experience
I just wanted to post what was wrong with my truck because I searched and searched and couldn't find anything, I luckily have a warranty on my truck and so maybe this will help someone who doesn't. My truck had this ticking sound that I thought was an exhaust leak, loss of power, start rough idling through the drive thru and it was run really rough when backing a trailer up. Brought it to the dealership to get it diagnosed and they said all those things are associated with bad cam phasers. They replaced them.. I'm going to pick it up tomorrow and will post an update. I hope this helps someone who was as lost as me. I was under my truck searching for holes in my exhaust, changed the oil, changed the spark plugs, changed air filters and still nothing fixed it. I really hope this helps.
Thanks.
Thanks.
I'm very surprised you didn't find anything searching. This is a very common issue with the 5.4 3 valve and there are a LOT of posts about it. To do the job RIGHT, the entire timing set should be replaced, along with a high volume Melling oil pump. I highly doubt the dealer will do all that.
Thanks.
Thanks.
How many miles on your truck? I have some model, same year, same engine.
I only have 75000 miles. it was my wifes grandpas pasture truck and he traded it in for a 2019 and then i bought it right after.
Load this up on YouTube, this is part 1 of 4. Parts 2, 3, and 4 are available in the right sidebar. The first comment has the full parts list with links, you can add up the prices. Labor? No idea, a flat rate manual should help.
https://www.youtube.com/watch?v=nQVKnd2r-ww
Thanks.
Thanks.
alright so I got my truck back today and they didnt fix the clicking sound. Kinda PO . They changed out some solenoid and gaskets. I argued with the mechanic and general manager on why they didn't fix it. Maybe someone here or GLC knows. I have a clicking sound coming from passenger side only when I accelerate. Doesn't happen if I'm in park and rev. Only when I'm accelerating in drive and sounds like its coming from right behind front passenger tire. If its something I can fix ill do it rather than send it to some dip at the dealership.
