Can't get in Truck...
Well, crap! I could have sworn that my 2010 had locks on both doors but I just went outside and looked and it doesn't!
My Maxima had a charging wire under the front left turn signal lens for situations like this but I guess Ford was too cheap to do that.
I wonder if the battery can be charged via the trailer power connector? (Assuming that the relay and fuse have been installed.)
Thanks for the suggestions and offers of help... I went over last saturday and hooked up a charger to the starter cables, worked like a charm... Waited a minute,hit the remote and the door unlocked... Put in a new battery on sunday and everything's working well...
I like to put a new battery on a trickle charger (battery tender) before installing, just to make sure it's fully charged...
The biggest problem I had was the original outlet wasn't hot... Crawled underneath, hooked the clamps up and then plugged in the charger, nada... Tried both plugs and luckily found another outlet on another building reasonably close... I did bring a small lamp down from mas apt to make sure it was hot, I was getting tired of crawling underneath...
Thanks again for all yall's help...
Kevin
Kevin
