towing help plz
That's exactly the link I posted.
Just to make sure, next time you go out with your rig and passengers, swing by a scale that can give you the weights of each axle individually. Add the front and rear truck axle weights, they should not exceed 7200# and neither axle weight should exceed the axle rating (front and rear GAWR, on the door sticker). You won't be over your tow rating or GCWR.
If for whatever reason I'm within 15% of the max, I'll probably just borrow the diesel. No need to be unsafe.
You will be safe up to the max GVWR (7200#) and max GAWR (front and rear). The EB will pull it almost like it isn't back there.
At 6000# with no pax or gear, you will probably be over GVWR with that trailer, even if you put all the gear in the trailer. You only have 1200# to play with for tongue weight and pax.
