Power Steering fluid any ATF ok to use?
I want replace the PS fluid on my 2010 FX4 and the owners manual calls for MERCON V however for auto trans it calls for MERCON LV (don't know the difference between them, if any).
Can I use any brand of ATF (ie. Delco, Penzoil, etc) or does it require a particular specification?
As a suggestion, you might want to consider Castrols High Mileage ATF Mercon V for your power steering. It has seal agents in it that will keep the seals nice and supple extending the life of the power steering system.
In regards to the LV ATF, it is not compatible with regular Mercon V. The LV stands for lower viscosity, meaning it's a thinner fluid. It's what makes the newer transmissions work better. Here's some reading for you:
http://www.imakenews.com/lng/e_artic....cfm?x=b11,0,w
I dropped in to a dealer on my way to the cottage this afternoon to pick the Mercon V and ended up walking out empty handed because not one of the 4 parts guys standing around and in plain view of me would even give so much as a glance to acknowledge my presence.
Talk about feeling less than, walking out nobody said a word but I was happy not to give them my business today or ever. And now that I just read Laberd's post about Castrol I'm even happier I didn't pickup the Mercon.
