Autospring Kit... Math just doesn't add up...
Old Mar 12, 2014 | 08:02 PM
OneFastGSXR's Avatar
All, I hate to beat a dead horse with this question but I am looking to put a Auto Spring kit in my '10 150... The kit I am looking at is a 2.5" up front and a 3" block in the rear. I currently have 2" of rake stock. If I am using this setup (strictly by the numbers) I will have 1 1/4" of rake after the install. I spoke with Auto Spring directly and they claim I will have only 1/2". How is this possible? Anyone with this kit that can confirm the true lift???
Thanks!
Old Mar 12, 2014 | 08:11 PM
F150redFx4's Avatar
The 3 inch block replaces your existing 1 1/4" ish block so therefore the rear lift is actually 1 1/2 - 1 3/4
Old Mar 12, 2014 | 08:18 PM
Yes, exactly. The lift in back will be 1.75", the lift in front will be 2.5". Currently have 2" stock rake. therefore, there is a residual of 1.25" after the lift is applied. Is my math flawed????
Old Mar 12, 2014 | 11:38 PM
thelariat02's Avatar
It would be a 3/4 -1" rake. depending on your stock block size and actual lift from AS.
Old Mar 12, 2014 | 11:52 PM
JohnBoy88's Avatar
This is all assuming his truck is 4WD. Stock 2WDs have no rear block.
Old Mar 13, 2014 | 02:08 AM
Autospring would be wrong about their own product in this case . . .
Old Mar 13, 2014 | 09:23 AM
Sorry, it is 4WD.
I would actually like a 1/2"-3/4" rake MAX. I do tow occasionally. Looks like I am going to be looking for a 2.5" Block. Can anyone attest that the 2.5" up front is actually what it measures after installation???
Old Mar 13, 2014 | 10:55 AM
Option number 2. Don't get a 3" block and do an AAL those come in different heights and you can get a 1" rise from them. And then you'll get your 1/2" rake
Old Mar 13, 2014 | 02:32 PM
pizzaman711's Avatar
Have you even measured your factory block yet to see how big it is? Seems like everyone just assumed it was 1 1/4" but the OP never confirmed it. OP when your measuring the rake, where are you measuring from?
Old Mar 13, 2014 | 03:22 PM
Yes I measured it... 1 1/4" Block for sure.... Measured stance from ground up to fender opening on a level surface, multiple times... Front measures 37 1/2", rear measures 39 1/2".
I was thinking AAL but wasn't too keen on the stiffer ride in the rear unloaded...
Old Mar 13, 2014 | 03:41 PM
They say long AAL don't stiffen it up much but are harder to install. Where the short ones are easy to install but cause a rougher ride.
Old Mar 13, 2014 | 07:43 PM
You can find 2 and 2.5" blocks, but personally, I'd just get the 3" anyway. Take is mostly a visual thing, and is most extreme when the gaps from fender to tire are small. So when both gaps are increased, the difference between the two is a much lower % of total gap, so it is less noticeable. Plus, every bit helps when towing. AAL wouldn't be a bad option either. I wish I had gotten AAL instead of blocks, just for the extreme increase in payload
