Looking for headers for a 126" wheel base scsb 2 wd truck
Hi,
Anyone know if any headers and catback can fir a shot wheel base truck? thanks!
2011-Up 1-3/4" Headers 3" Y-Pipe With No Cats Ext. Pipe To Muffler F150L34N/C
2011-Up 3" S/S Cat Back F150CTBK11
And what is best y pipe or x pipe? what is the difference? thanks!
http://www.stage3motorsports.com/F15...-Off-Road.html
I believe they will fit, I see no reason why they wouldn't.
BTW there are only 2 brands of long tubes that fit the coyote 5.0 in 2011 up 150's. They are
http://www.americanracingheaders.com...F150_5.0L.html
and
http://www.stainlessworks.net/featur...4-headers.html
and
and
and
Headers should fit regardless, exhaust after the headers will be the issue.
I plan on using the stainless works headers on mine when I have the spare coin to spend. I do know that SW uses T-304 stainless for all their exhaust products IDK what grade of stainless american racing headers uses. There are two grades of stainless used in exhausts, T-304 and T-409, the 304 is better and more expensive.
The biggest reason I'm going with SW is they are local to me, and I'm all about supporting a local business if I can.
Every 5.0 truck should be exactly the same from front bumper through at least part of the cab, if not further back. I don't know why they say you need xx wheelbase for just the headers, but I know why you would be concerned. You may have to go custom after, no kit, after the headers or mid pipe, but the headers themselves should go on fine. I think if these kits come with the mid pipe right after the collectors, the mounting points for mid pipe are what are wheelbase specific.
I'm curious as to where your frame has been shortened. The reg cab 8 foot bed, scab 6.5 ft bed, and screw 5.5 ft bed all have the exact same frame, and I'm led to think the exact same mounting points for all the exhaust hangers.
