How to remove ford oval on tailgate??
Old Oct 7, 2013 | 06:49 PM
speedstang's Avatar
Anyone know how to remove the ford oval emblem on the tailgate w/ camera??
Also, without breaking it. I took mine off to paint it and broke the tabs. My father in-law has a hennessey raptor emblem to put on his raptor and need to take the ford emblem off. Figures, it did not come with any directions. If I don't get any replies, I guess I will be calling them tomorrow.
Old Oct 7, 2013 | 07:54 PM
gDMJoe's Avatar
It's held-on by double-sided tape.
  • park the vehicle so that the tailgate faces the sun. *The object is to heat-up the emblem. This can also be done using (say) a hair dryer.
  • use nylon pry bars to slowly pry-up the edge of the emblem by working around the perimeter.
    *Can be purchased at Harbor Freight.
  • use mineral spirits and/or GOOF OFF to remove the tape residue.
Old Oct 7, 2013 | 08:57 PM
speedstang's Avatar
Mine was not held on with touble sided tape. There r 2 tabs that somehow slide in n lock. I broke the tabs on mine when taking off. Didnt want to do that to his.
Old Oct 7, 2013 | 09:02 PM
SmokeRoss's Avatar
A friend of mine replaced all his with Peterbilt ovals. Doubt he did it himself though.
Old Oct 8, 2013 | 10:46 AM
gDMJoe's Avatar
speedstang] - Mine was not held on with touble sided tape. There r 2 tabs that somehow slide in n lock. I broke the tabs on mine when taking off. Didnt want to do that to his.
My bad/mis' ... T'is true the backup cameral Ford oval is different.
Old Oct 8, 2013 | 10:48 AM
Pockets's Avatar
Take the panel off the lift gate to look inside? That might let you just pop it off from the inside
Old Oct 8, 2013 | 04:42 PM
speedstang's Avatar
Negative...I tried from the inside and you cant get to it. After you pop the ford part off as pictured above, there are 2 bolts holding main part of emblem to tailgate.
Old Oct 8, 2013 | 05:12 PM
Get an alldatadiy account (which is good to have anyway) and check on there?
