So 2.5 AS leveling kit=nose high 2011 4x4?
Just received mine in the mail and as I'm reading through some posts I see some people claim it makes it front end high, while others don't. Anyone know?
Supposedly on the 09+ trucks, an AS 1.5" gets you level and actually gives you 2" lift. (AS 1.5" and HBS 2" are the same dimensions)
Run your AS 2.5" in front, pick up a set of raptor blocks (2.5") for the back, and swap them for your OE blocks (1.25") for a 1.25" boost in the rear.
on 09 and up go 1.5 or 2 if you want to be level. 2.5 will be slightly nose high. o4-08 can get away with 2.5, but i still have just a 2 on my 04. anyways if youre looking for level on a 2011 go witha 2
link in sig, also sticky'd in the suspension section, would tell you 2" gets you level on the 06+ trucks.
04-05 had a different leaf pack requiring 2.5" to get level.
Good call. I've seen many 2.5's sit about an inch nose high. My 08 SD was the same way. I want to buy a "LEVELING KIT" so I can make my front level with the rear. Not to add crap to the back to make it level after buying and installing the "leveling kit"
The safest bet is the 1.5" or I've even seen a 1". Both of these actually get the truck level.
.The safest bet is the 1.5" or I've even seen a 1". Both of these actually get the truck level.
I still have 1/2" of rake with my 2" Autospring. I've seen the results (amount of lift) vary slightly depending on SCew vs. SCab , new struts vs. older struts and one brand of leveling kit vs. another brand.
On a different note, did anyone else purchase an AS kit that looks like a five year old welded it together? I'm sure the welds are strong but it's not nearly as clean looking as the HBS kit I put on my 05 (not that you can actually see the thing once it's installed anyway).
I prefer the Autospring because of the gussets welded in for added strength. FWIW, I've never seen steel leveling kit spacers fail so they are all probably good enough. I have seen a poly spacer split. Not sure if it was a Daystar or some no name brand? But the truck was driven beyond it's limits when the spacer split.
