Sponsored by: DashLynx
Oh oh
Old 02-21-2011, 02:28 PM
camunaro's Avatar
Oh oh
today i put my truck in 4x4 ( 2010 fx4 ) i was at a stop when i did it, as soon as i gave a little gas there was a HUGE bang ( the whole truck shook)....sounded like from the rear end then a grinding sound from the front drivers side wheel.
ive heard the grinding before but never the HUGE bang
any ideas
Old 02-21-2011, 02:38 PM
ruffn-it's Avatar
Please tell me you weren't on dry pavement. Did it go away after the initial bang?
Old 02-21-2011, 02:44 PM
camunaro's Avatar
no i was on ice.....trying to climb a small hill outside of the car wash, i was at the bottom of the hill ( i couldnt make it up in 2 wheel ) so i backed up to the bottom of the hill stopped and put it in 4x4 started to creep forward very easily and then thats when the bang happened. once i made it to the top of the hill ( maybe about 25 feet in distance) i turned the corner and put the truck back in 2 wheel. after the bang there was a slight grinding sound but once in 2x4 the ginding stopped
Old 02-21-2011, 02:47 PM
ChrisT's Avatar
Better get to the dealer and have that looked at ASAP! That's what that warranty is for on that nice new truck you bought.
Old 02-21-2011, 02:50 PM
camunaro's Avatar
it will be looked at forsure.....BUT i was hoping to go in to the dealership with some kind of idea incase they try and say nothing is wrong. the only thing i can think of is the hub. but that doesnt explain the bang from the rear end
Old 02-21-2011, 02:52 PM
coobies5's Avatar
abs?
Old 02-21-2011, 02:56 PM
camunaro's Avatar
no idea.......would ABS bang like that.
Old 02-21-2011, 02:58 PM
ChrisT's Avatar
Well based on what you've described, it definitely sounds like something is biding up in the front drive train area. I don't know the mechanics of it all enough to say specifically what, but being as it went away when you switched back to 2WD, I think it's safe to say that's what's wrong (front drive train issue).
Hopefully everything is fine. I've heard many people here post about "loud bang, grinding noises, binding feeling", etc. cause they engaged their 4wd on a surface that was not slippery in anyway. Usually everything is ok (it is a Ford after all ) but they learn quickly not to do that again.
Old 02-21-2011, 03:09 PM
camunaro's Avatar
lol.....thats a good bet, thinking it is the front drive train. but i didnt know that it would effect the rear end either. i guess ill have to go to the dealership and get the run around ( im sure they are not going to be willing to make this easy)
Old 02-21-2011, 03:13 PM
ChrisT's Avatar
Yeah, definitely would be a good idea to have it checked. But like I said, hopefully everything is OK. What region do you live in? Could you go try out the 4WD in some snow or ice in your area? If so, you might find (hopefully) that the noise is gone and everything is working fine. Might have just been a fluke thing where the front diff got bound up, for what ever reason.
Old 02-21-2011, 03:26 PM
RES4CUE's Avatar
Did you try to put it in 4wd again to see if it happens? Sometimes it can bang and clunk if there is drivetrain bind.
Old 02-21-2011, 03:27 PM
camunaro's Avatar
yeah, ill make the apt tomorrow i guess. im in Alberta Canada so there is alot of snow....lol
ill keep you posted. thanks for your help and ideas
Old 02-21-2011, 04:02 PM
camunaro's Avatar
no but i will try again soon. roads are to dry right now.
is drivetrain bind common?
Old 02-21-2011, 04:15 PM
ruffn-it's Avatar
I notice just a minor pop in the front end if making a somewhat tight turn. So I try not to do that. I wonder if the rear pop was caused by a load on the truck. Like when shifting out of park when on an incline, I get it occasionally when on the boat ramp, I try using the e brake to stop it. Maybe since you said you were trying to go up that hill you had a load on the drivetrain when it shifted into 4x4.
Old 02-21-2011, 04:25 PM
Bigsmitty01's Avatar
Last Feb after the big snow here in VA I was on a dirt drive way dead stop for a couple minutes put my 2010 in 4wd hi and when I steped on the gas I too heard a loud bang in the truck sounded like the front diff, it was it had split all the way around the front pumpkin and blew a piece of the housing out the size of a tennis ball 787 on the miles. Went to ford the next day and they said they had never seen anything like it they replaced the whole front end axles and all.
