EcoBoost MPG!!!!!!
Old Dec 26, 2010 | 11:28 AM
  #61
Power Kid's Avatar
Originally Posted by 1depd
Not if they were going for max fuel economy. The larger tank results in more weight having to be carried, lowering fuel economy. Just the gasoline will weigh an extra 60 lbs in addition to the extra metal in the gas tank.
So if I'm towing 5-9,000 bs for example 75lbs will matter. C'mon.
Making sure my trailer tires are at max psi will make a bigger diff than that. Never mind countless other things.
Go tell that to a long distance trucker... his tanks should be much smaller so he gets better mileage...
And don't forget you would still be able to save 99% of that weight. Just don't fill it up all the way.
Old Dec 26, 2010 | 01:02 PM
  #62
1depd's Avatar
Last I checked the EPA does not do MPG testing towing a trailer. I must admit it has been several years since I looked though. 75 lbs isn't much, but add that to the other weight savings Ford was able to put into the truck and pretty soon it is a good number with cooresponding fuel consumption improvement.
Old Dec 26, 2010 | 09:20 PM
  #63
tstjohn's Avatar
Is it possible that Ford has a reason for not offering the large tank with the EB instead of it being a "stupid mistake"?
Maybe it has to do with the direct injection system?
Old Dec 26, 2010 | 09:26 PM
  #64
johndeerefarmer's Avatar
nope.
36 gallon tank is available with the ecoboost with the 8' bed on certain configurations. A guy over on Blue Oval forums has one on order
Old Dec 27, 2010 | 09:30 AM
  #65
tstjohn's Avatar
Originally Posted by johndeerefarmer
nope.
Interesting to see if that's possible. The original order guide says Ecoboost gets a 26 gallon tank, period.
