First Oil Change
Old Nov 5, 2010 | 10:04 PM
  #31
johnwill's Avatar
You are welcome. And yes, buy one now before your next oil change, or you will always be chasing your tail. Order from where I said above and use the discount code. It has been around for about 5 years but STILL WORKS. Order two from the other place and get free shipping.
A thing of beauty:
Old Nov 6, 2010 | 01:40 PM
  #32
99and04f150's Avatar
Any word on the oil analysis? I am anxious to here what they say as it may have me changing my oil sooner, of course I only have 500 miles on my truck.
Old Nov 6, 2010 | 05:11 PM
  #33
02scabfx4's Avatar
I just ordered a valve for my truck too! Wish I would have found out about this sooner.
Old Nov 7, 2010 | 05:28 PM
  #34
Rotorguy's Avatar
Just did my first oil change on my '10 4.6 3V (1500 miles) and what a mess!!!!
My drain pan was just a little too small for all of the oil and it over flowed a small amount. The filter was tight, but a strap wrench broke it loose after a lot of grunting. The filter drain plastic thingy directed oil all over the place. I ended up removing it in order to clean up the mess (two 8MM bolts). After I got it off, it looks like the filter change would be easier with it out of the way. I think I'll try that next time. I used a half a roll of paper towels and a can of brake parts cleaner just to clean up the garage floor!
I then cleaned the cross member and plastic thingy and reinstalled it after filling with oil and checking for leaks. Overall it took 1 hr but I also vacuumed the interior and checked my tire pressure.
Old Nov 8, 2010 | 10:53 AM
  #35
5pointslow's Avatar
me too.
Old Nov 8, 2010 | 11:00 AM
  #36
shotgunz's Avatar
https://www.f150online.com/forums/20...is-report.html
Old Nov 8, 2010 | 11:08 AM
  #37
Thanks. I will probably dump the factory at 3k and then switch over to Mobil One, ran that in my 04 and changed it every 6,000 miles. My driving is about 90% highway with no traffic (God Bless Central Illinois).
Old Nov 8, 2010 | 11:19 AM
  #38
shotgunz's Avatar
I'm sticking with 7500 miles (5000 miles during the summer as I tow my boat quite often) and MC 5w20 semi-synthetic.
7 quarts MC 5w20: = $11.95 (5 QT jug) + 2/5 x ($11.95) = $16.73
FL820S = $4.15
Total: $20.88
But this will likely start another discussion on what oil and filter to use.
Bottom line: your truck, your money, do what makes you feel good.
Old Nov 8, 2010 | 11:23 AM
  #39
Amen.
Old Nov 8, 2010 | 01:18 PM
  #40
If you do that, use the EP formulation, not the standard stuff.
Old Nov 8, 2010 | 01:57 PM
  #41
EP? Hmmm heard of it, but don't know anything about it. Someone educate me.....
My productivity at work has fallen off sharply since I took delivery of my new truck. Oh well.
Old Nov 8, 2010 | 02:18 PM
  #42
johnwill's Avatar
What is the best filter to use on these trucks?
Old Nov 8, 2010 | 06:18 PM
  #43
Mobil 1 EP - the extended performance blend. It has a lot more synthetic in it than the standard blend and lasts longer. It's only about 50 cents more a quart than the standard.
For 7500 mile or less drain intervals, a Motorcraft. A Wix or Purolator is also good. For long drain intervals with synthetic oil, a Mobil 1, K&N, or Amsoil.
Old Nov 8, 2010 | 08:24 PM
  #44
johnwill's Avatar
Thanks for the comeback on the filter.
But, what does " a lot more synthetic in it" mean when comparing to other synthetic oil? Does bottled water have a lot more water in it compared to tap water etc?
Old Nov 9, 2010 | 01:50 AM
  #45
Mobil 1 is a Group 3 dino synthetic. It's really not that much different than the Motorcraft synthetic "blend". The EP has a lot of Group 4 true synthetic in it. Group 3 is allowed to be marketed as "synthetic" only in the US.
