Where does the 2" difference come from 2wd to 4wd?
Old Oct 25, 2010 | 09:22 AM
  #31
Formula jg's Avatar
Thanks for the parts info. My truck is a '10 FX4 and I thought I read here some where that the U-bolts can be reused when removing the blocks on 2010 4x4 models??
Well I put a halt to my plans to remove the blocks cause I discovered a sqeak in the rear suspension when I jump on the bed. So I made an appointment tomorrow for the 10K service (oil change and tire rotation)and will have them inspect the leaf springs then. Just have a gut feeling they would have blamed the squeak on the missing blocks if I had removed them, so I'll wait to see what they tell me.
Old Oct 26, 2010 | 03:16 PM
  #32
Formula jg's Avatar
So I was at the dealer for my 10K service (oh btw, do all service reps think that all customers don't have a mechanical clue about vehicles?) and they couldn't check the squeaky rear suspension because "the suspension guy is tied up on another job". So asked if he can come out for 2 minutes just to confirm the noisy suspension and then I'll book another appointment to have it looked at more closely. In a nut shell they said he couldn't and that I have plenty of time to deal with this if its under warranty.
Anyway I go over to the parts dept. to get a price on the shorter U-bolts WOW they wanted $20/each. Checked the TASCA link from greencrew (thanks again) and thats much more like it $10.27/ea however it notes the years 04 to 08 will they still work for my 2010?
Old Oct 26, 2010 | 03:35 PM
  #33
jlsworks's Avatar
Hi Formula jg, can you post the part numbers you found for the suspension bits your installing?
Thanks, James
Old Oct 26, 2010 | 03:38 PM
  #34
Formula jg's Avatar
jlsworks,
See post #29 by greencrew, he notes the Ford part no for the shorter U-bolts.
Old Oct 26, 2010 | 10:41 PM
  #35
J T Ford's Avatar
YOU DON'T NEED THE SHORTER BOLTS, after the blocks come out just run the nuts up and forget it! There is 2 inches of threads below the nut and still threads above the nut also......................................
Old Oct 27, 2010 | 08:38 AM
  #36
Formula jg's Avatar
JT,
You just saved me about $100 thank you very much.
Old Oct 27, 2010 | 01:22 PM
  #37
marshal's Avatar
worst comes to worse, take an angle grinder and cut the excess off of the bolts, then take a piece of tool steel sharpener and take the burrs off the edges
Old Dec 4, 2010 | 01:02 PM
  #38
jlsworks's Avatar
Just an update on my new Level Kit and rear blocks...
Before
After
Old Dec 4, 2010 | 01:30 PM
  #39
TJALOHA's Avatar
jls: what size and brand leveling kit did you finally end up going with? I installed a 2" ProComp and 4wd struts on my 2wd and am having some issues with the coils hitting the spindles and UCA's during suspension extension.
Old Dec 4, 2010 | 01:43 PM
  #40
jlsworks's Avatar
I have the AS 1.5" (1.25" actual spacer height) Level Kit and the 04-08 OEM Rear blocks (1 7/8"). I went from 36.75" front fender height to 39" and 39" rear fender height to 40.5" after the alignment.
Yes, I too have the coil and uca issue and I'm not happy about it, I understand AS now offers an "offset" spacer that eliminates this problem.
Old Dec 4, 2010 | 02:03 PM
  #41
RemoAZ's Avatar
Your truck looks sweet! New tires coming? Looks like you could fit 35s under there.
Old Dec 4, 2010 | 04:17 PM
  #42
jlsworks's Avatar
Thanks, I'm eventually going to go with the 305/55/20's.
James
