How do u adjust ebrake on a 2010. No Search results...
I thought it was funny too why I had to push the ebrake down about 3/4 of the way down so I thought I would try to adjust it. But, you are right, I shouldnt have to. And I noticed that even when i am on small hills and I push down hard on the ebrake it still doesnt grab very good and still will put the transmission in a bind which is something you dont want to do.
It is adjusted just like drum brakes. At the back of the brake will be either an opening or an opening with a rubber plug so you can use a brake adjusting tool (or screwdriver) to move the star wheel to loosen or tighten the brakes. Has nothing whatsoever to do with the cable. It has been that setup since at least 04.
I know what you are saying and I apprecaite that but I dont have drums in the rear. Those adjusters are within the drum and you take off the rubber and use a flat head to move them but thats not what I have. I have rotors in the rear. Dang dealerships dont like having the techs show you how to do things.
