Flip Key / Remote
I didn't realize that. Is there just the one screw to undo on the back, or is there additional procedures needed to get the key apart?
Did you ever get it? How long did it take to get it? Whats the quality like and how hard was it to program? Been thinking of buying one and found this thread. That is the seller I was looking at too. Thanks
Here is one just like this one, but cheaper.....:http://www.ebay.com/itm/300667689750...84.m1439.l2649 got mine today, programmed and working great. Only one problem, you will have to take the blade (key) off to get it cut. It's not a problem, there is a very tiny roll pin that holds it on just find a very small punch to remove it. Took the 'blade' and a good key to the dealer and they cut it for free. It works great!!
Well i pulled the trigger last week and purchased one of the flip key . I recived the key yesterday and after going to the dealership and them telling me the fob part of the key was to big to fit in there machine and Homedepo telling me it was a chipped key and they wanted $65 to cut it I went home and thought about it and took a chance and took the fob apart to try and gain access to just the key . I found that if you remove the little ford symbol there are 2 little phillips head screws there remove them and the key shank will come right out then looking at the shank there are tiny phillips heads screrws you remove them and there you have just the key shank. I then took it back to the dealer to have it cut and with no problems I might add. Get home reassimble the key to the fob and presto its as good as new. I did the programing my sefl in the drive way it took about 10-15 min total asper the Ford owners Manual and so far it seems to work great.. I'll report back in a week to update on the flip key..
