Still no 5100's or coilovers out for our 09-10's except KING
Anyone pull the trigger on some King coilovers? I spoke to King and they said they barely give any lift at all.
I am waiting for someone like Fox, Camburg etc. to come out with a UCA coilover kit that allows lift without compromising some angles. Hopefully something soon I am sick of being back at stock height in front ever since I removed my 2" AS spacers that gave me terrible problems.
Pro Comp Coilovers
Pro Comp has a set out for the 09's. BlackPlatBDS has a set on his truck.
https://www.f150online.com/forums/su...acer-gone.html
My UCA's were hitting my coils on any dips, turns, bumps causing my traction control to initiate. It was very annoying. I posted a thread with pics.
I'm confused.. You want to level the truck or you are lifted and want more lift? either way its tough to avoid some kind of rubbing/ hitting of the uca on the coil. Mine does both if the conditions are right.
I am guessing Camburg will eventually make a coilover+UCA for the new models. Probably will be a good choice.
if they hit the coil with a 2inch leveling kit they will also hit with any other 2 inch lift, bilsteins ect..the only way around this would be to install a coilover with a spring that is smaller in diameter like the ones posted above.
Anybody have a picture of the spacer prior to install showing the offset?
Yea that is what I am thinking.. I plan to upgrade the UCA's to eliminate this issue.
I really don't want to go spacer especially since I already had such problems with only 2" AS kit. They said that it was offset but it didn't look too offset.
Rancho has a kit just like the 5100 from Bilstein - not a spacer.
I couldn't find much about these other than the price (~$200/shock). Their site is pretty slim on details/installation instructions, etc.
http://www.gorancho.com/products/shocks/quicklift.php
On a side note, I emailed both King and Pro Comp seeing if they are planning on offering a leveling shock.
The response I got from King was:
Sounded pretty intelligent for a guy whose e-mail signature says "VP - Operations & Sales"...
From what I could tell the Pro Comp ones referenced earlier in this thread are for already-lifted trucks, not for stock trucks looking for a front level. Sure enough, they replied:
I was wondering if you offer adjustable shocks/coilovers that can be used as a front leveling solution for the 2009 F-150 (4wd)
The 09 f-150 will be release in 2 weeks and you can get 0-2.5 lift
We do have plans for just that kind of product due for release later this year or early next year.
