Added Harley / Raptor Taillights *PICS
Nice picture on p.61 of the manual. I am not being a wise-***, if I had a nice pic I would post it here instead.
When you pop hood, it is all right there. Two of the screws are right on top of the headlamp assy, and the third is down along the side, inboard. And, the plastic pushpin with the phillips head (you can just yank on if you wish, or a couple of turns out) is on the rubber flap next to assy.
Once you eyeball the assy under the hood you will see what I mean and see that it is super simple no problems. Everything is right there, no contortions needed. Good luck.
That's right , I did for 2 reasons !
I"m trying to find out if the 2009 HEADLIGHT part numbers are the same as 2010 . With the holiday season, and everything I have going on right now, I had totally forgotten about my previous posts, my mistake
I have had my local Ford parts man tell me that the TAILS are "slightly " different, and have seen several different numbers for / and stamped on them. Then I'm told by another they are all the same and interchangeable, only different numbers ? I wanted to see if this is the case with the headlights as well ? And YES , at $193.00+ shipping each , they are too expensive, but thought " just maybe " someone might have a cheaper source where they can be found ....or even a very nice / like new used set ,I guess not !
Excuse me, if I have inconvenienced anyone with this, and thanks for the help
Have a Merry Christmas ! :santa:
I have had my local Ford parts man tell me that the TAILS are "slightly " different, and have seen several different numbers for / and stamped on them. Then I'm told by another they are all the same and interchangeable, only different numbers ? I wanted to see if this is the case with the headlights as well ? And YES , at $193.00+ shipping each , they are too expensive, but thought " just maybe " someone might have a cheaper source where they can be found ....or even a very nice / like new used set ,I guess not !Excuse me, if I have inconvenienced anyone with this, and thanks for the help
Ok, that's a big help , and pretty much what I was lookin' for ,thanks.
I still think they're waaaay over priced and will continue to search for a cheaper set, { even a very nice used pair }, at least till I hit the lottery !!!!
Hope you have a great holiday ? :santa:
