Rust in 08 Screw cab corner
Old May 18, 2017 | 01:03 AM
Benito Alonso's Avatar
If your cab corners are getting rust you should get them fixed. I had that problem with my 08 king ranch and ignored it, before I knew i was driving around with two big wholes in my cab corners. I ordered mine online and had them spray some bed liner on the inside of the cab corners since that's where the rust originated from. Hopefully I won't have to deal with this problem again.
Old May 18, 2017 | 11:56 AM
CJB XLT's Avatar
Read the entire thread. I did have it repaired and glad I did. I wanted to contain the rust before it got out of control. I knew it would only get worse and the cost for repair would only go up.
Old May 26, 2017 | 03:47 AM
Rothstein1987's Avatar
This could possibly be the culprit of all the cab corner problems<br/>
Old May 26, 2017 | 03:48 AM
That is if you have a moonroof and dont clean your drains regularly anyway
Old May 26, 2017 | 12:03 PM
CJB XLT's Avatar
My truck does not have a moon roof. It doesn't appear anything is wet on the interior like the 3rd brake light or rear slider would be leaking. It did appear as if the rust started on the inside, though. The underneath or inside of the rocker panel looked to be ok too. I have no idea what initiated it.
Old May 26, 2017 | 12:15 PM
Well that's strange I haven't seen many non moonroofs rust out like that mine are getting fixed next week and we are putting in proper moonroof drains
Old Jul 17, 2017 | 07:33 PM
jasonrw's Avatar
Same deal
I have the exact same problem in exactly the same area on my '08 F-150 SCrew except I don't have $1,300.00 to fix it. I have to do this all myself...
Old Jul 18, 2017 | 12:23 PM
CJB XLT's Avatar
Good luck. I have repaired many rust spots myself on my vehicles over the years. Fortunately, they have always been in the wheel wells prior to this. I wouldn't be able to make it look good enough for the exterior.
Old Oct 17, 2019 | 01:18 AM
Mizzou-rah's Avatar
rocker panels gone
Have had this 2010 Platinum for just under 2 years. Everything looked solid when we had it on the lift and my mechanic inspected it. Last year we had some hellacious rainstorms in Kansas City and I noticed the rear corners of the headliner were wet. Traced the problem to the gasket on the 3rd brake light.
Fast forward to this year and noticed the sheet metal peeling off on the rocker panels. Getting an estimate but my body shop first said it could be poor drainage from the sun roof. Then I pointed out the 3rd brake light issue I'd discovered and fixed.
Not very pleased as I got rid of a 1999 F-150 with 265,000 miles that had very little rust when I sold it in 2017.
Old Oct 17, 2019 | 01:08 PM
tbear853's Avatar
Originally Posted by CJB XLT
Well, it has been a while since I first posted this. I ended up having the rust repaired. It cost about $900. They did not have to remove the bed. I didn't have to purchase the sheet metal. They were able to fabricate a piece for it, instead. I think it turned out pretty good. Now I hope it lasts for a long time with no new spots popping up.
Sorry for the dirty pic. I should have cleaned some of the nasty pollen off first.
I know, old thread up to last post. Repair looks Great!
I've seen some rusty corners, usually on moon roof trucks. It's not common and I cringe when I see it. Keep mine parked in a carport I had erected a year after getting the truck to protect interior from sun and …. maybe prevent this. I am retired so when snow / ice / salt on roads, not a lot of reason to be on the road myself.
Old Oct 18, 2019 | 10:10 AM
CJB XLT's Avatar
I think my rust issues were related to a 3rd brake light leak. It has since been replaced. Unfortunately, a little too late.
Old Oct 20, 2019 | 09:48 AM
Doublet74's Avatar
Since you had it fixed there is a way to prevent it from happening. I live in the NE the rusty truck capital. What i did was to put a little motor oil in the hollow spaces. Ie: doors, fender walls, etc. This prevents the water from sitting there. The oil doesn't rust your panels. I know your thinking thats crazy but it is an OLD trick that has worked fantastically for me. Just saying it couldn't hurt and might save you $900 in the future.
