How to: Fix blank or dim radio backlight
Old 04-23-2015, 05:16 PM
2008_XL's Avatar
Tools needed:
7mm socket
T-10
Soldering iron
Solder
Trim remova tool or butter knife
If your 2004-2008 backlights are not working properly, this will fix your issue on your OE radio.
Most will say this is not fixable, however, after doing some research, it's an easy fix. There are radio repare companies out there that are charging $19.99 just for these instructions!
Before. Dimly lit and not readable:
How to: Fix blank or dim radio backlight-atgroyl.jpg
Step 1.
Remove trim around radio. Start at the bottom and pry out.
How to: Fix blank or dim radio backlight-rgewjo3.jpg
Keep you'll feel the trim pop out as you keep pulling.
How to: Fix blank or dim radio backlight-41nelsn.jpg
Step 2.
Disconnect airbag warning light. It's located at the top backside of the trim piece. Push in the tab and it comes out easily.
How to: Fix blank or dim radio backlight-abterrc.jpg
Step 3.
Remove the four 7mm screws on the four corners of the radio.
How to: Fix blank or dim radio backlight-au3jebs.jpg
Step 4.
Not pictured, remove harness and antennae plug from rear of radio.
Step 5.
Remove the four T-10 screws located on the front top and bottom (face) of the radio and pull the face off. It will come off easily.
How to: Fix blank or dim radio backlight-mgwe6fv.jpg
Step 6.
Flip the face over and locate the spots to solder as shown below. They all say "180" on them and there are 4 that need soldering on both sides.
How to: Fix blank or dim radio backlight-r2flj5r.jpg
Add solder to the 8 points.
How to: Fix blank or dim radio backlight-ac8vkfq.jpg
Now reassemble and enjoy the backlight working normally again.
How to: Fix blank or dim radio backlight-uf3w3fk.jpg
Old 04-24-2015, 09:29 AM
mod600's Avatar
Did this last summer the wife's Explorer radio. Worked like a charm and is still working.
Old 04-24-2015, 09:47 AM
RevBiker's Avatar
2008 XL,Thanks for the great post, Don't have a problem with my radio yet, but its nice to see how its fixed just in case I need to do it in the future! Does anyone know if there is one place on the site where ALL the fixes are listed w/o reading every post out there. If not it would be great to see one. Like Radio fixes, window fixes, rear end fixes, tail light fixes, etc... Just an idea.
Old 04-24-2015, 09:59 AM
glc is offline
Old 04-24-2015, 10:21 AM
2008_XL's Avatar
You're right. And I should have posted it there. I think I added it here due to more traffic and this seeming to be a common issue.
Maybe a mod could add this to that section?
RevBiker's Avatar
Thanks glc
Old 04-24-2015, 11:10 AM
glc is offline
That's how the articles are done - the mods copy them to the articles forum after they are posted elsewhere and vetted.
Old 04-24-2015, 11:17 AM
I copied this to our Articles and How To section. Thanks for another nice write up and great contribution to our site.
Old 04-24-2015, 11:46 AM
2008_XL's Avatar
Of course! thanks for the kind words!
Old 04-24-2015, 01:50 PM
JackandJanet's Avatar
Just to add, there's a "clickable index" in the How To section that takes you right to an article you may be interested in. It's divided into sections, much like you suggested. https://www.f150online.com/forums/ar...-articles.html
- Jack
Old 11-20-2016, 04:35 PM
Scott3708's Avatar
06 and up CD6 displays
Well the resistors are an issue however there is another. There are 8 other power connections for the display they are the two through hole junctions at the extreme corners where the display solders to the board. All eight of mine were fractured from pushing on display to get it to turn on. Just a touch of an iron with some fine flux core solder re-flowed the solder on mine, about 3 seconds is all it took just as the solder joint goes liquid count to 3 and remove. Reinstalled and OOPA display again. Hope that helps
Attached Thumbnails How to: Fix blank or dim radio backlight-gallery_19614_475_43523.jpg
Old 03-18-2017, 11:26 AM
gis514's Avatar
OEM radio illumination
Hi,
I just bought a used 2008 F150 and the radio has no illumination on the controls. Image of my radio attached.
I'm referring to the the *****, preset buttons, CD, AM, FM, SEEK, MENU, VOL-PUSH etc..
The display does light up (clock, stations etc..)
Maybe these never light up. Unsure. Does anyone?
File Type: docx
Old 03-18-2017, 11:35 AM
2008_XL's Avatar
Originally Posted by gis514
Hi,
Not sure what that file is as it definitely doesn't work in safari. But the buttons do not light up.
Old 03-18-2017, 11:50 AM
gis514's Avatar
Thanks.
The file was just an image of my OEM stock radio.
Old 03-18-2017, 12:08 PM
glc is offline
It's a Microsoft Word 2007+ file.
Quick Reply: How to: Fix blank or dim radio backlight
