Optional Equipment
Old Mar 18, 2015 | 04:52 PM
Cobra Jet's Avatar
Originally Posted by 2008_XL
I believe the 7200# gvwr is just the standard package as the 8200# is the heavy duty one. Also, the 508a I believe is just a standard package in the lariat.
If the 7200 is the standard package, what truck would get the 7050 you mentioned? Would that be the 2WD?
Old Mar 18, 2015 | 04:59 PM
Cobra Jet's Avatar
Originally Posted by SoonerTruck
I guess I was questioning Load D/E LT tires, it didn't even occur that Ford would bother with C tires given that they are generally pretty close in loading to most truck/suv P-metric tires. I had LT-E terra grapplers for my last set but went back down to the P-metric version for the latest set due to the harsh riding characteristics of the LT's (only kept them at 50psi).
Do the P-metric tires look different than the LT tires. For some reason I always thought they might look more like a regular car tire after they were installed.
Old Mar 18, 2015 | 05:13 PM
2008_XL's Avatar
Most look exactly the same of they're within the same series. Some companies offer a totally different series for their LT's, but that would only include load E.
But take the Cooper dicoverer for example, p metric, LT load c and LT load e all look identical. LT's may have slightly deeper tread. 14/32nd on a p metric vs 16.5/32nd on an LT. Not that it'll even effect the longivity though.
Old Mar 18, 2015 | 05:39 PM
SoonerTruck's Avatar
Agreed, most of them look pretty much identical to the P-series. They are just a much stiffer tire compound. I could air the LT (E) tires up to 80psi if needed in order to get max loading capacity, but I ran 'em with 50psi for every-day driving in order to keep the truck from being shaken apart, lol. I got some pretty bad wheel hop over bumps even at 50psi.
Old Mar 18, 2015 | 05:41 PM
My Screw Lariat 2WD has the 7050# option and the factory towing package.
Old Mar 18, 2015 | 05:42 PM
2008_XL's Avatar
I agree. I too went from LT back to a p metic recently and the ride is much nicer.
Old Mar 20, 2015 | 10:29 AM
tbear853's Avatar
My '07 FX4 Scab Fside's Sticker reads:
"PREFERRED EQUIPMENT PKG. 505A" with no entry under costs
followed by:
"P275/50R20 OWL ALL-TERRAIN" with notation "NO CHARGE"
and below that is:
"3.55 RATIO LIMITED SLIP AXLE" with notation "NO CHARGE"
and then the next line is:
"7200# GVWR PACKAGE" with no entry under costs.
If it helps any in the discussion?
