troyer performance trans cooler
Old Sep 7, 2013 | 10:18 AM
4 da boat's Avatar
If 200 + is the norm what is the lower temp with the Troyer upgrade ?
Old Sep 7, 2013 | 05:35 PM
MeanGene's Avatar
Norm when running empty or towing?
Old Sep 7, 2013 | 06:08 PM
MeanGene's Avatar
Here is what my temps looked like at there worst. Pulling a 23' trailer up a mountain grade with no trailer package. Single row radiator, stock trans cooler. 11,500 GCVW
Old Sep 7, 2013 | 06:50 PM
dbhost's Avatar
I would think you have a problem aside from the cooler. Mind you, more air moving through the cooler is best, but the OEM HD cooler is pretty darned big. If Assuming you don't have any blockages, what else is going on such as fluids that could be causing this? How many miles on the trans?
Old Sep 7, 2013 | 08:47 PM
a.desisto's Avatar
I'm pretty sure Mercon V can go around 250°F without losing its lubrication properties. So if you're having transmission problems just above 200°, your transmission has an issue.
Old Sep 8, 2013 | 01:14 AM
Or, like I said, the fluid has already broken down.
Old Sep 9, 2013 | 05:55 PM
wyattboche's Avatar
Originally Posted by glc
200 to 220 should not cause problems. If it's slipping when it hits 200, your fluid is broken down. Get a complete exchange with a good synthetic ATF such as Amsoil.
Running royal purple
Old Sep 10, 2013 | 10:16 AM
dbhost's Avatar
You have something else going on in that trans I suspect if you are getting slippage that early...
