replace passenger lower ball joint...now noise from drivers side??
I wasnt sure what was causing the noise so I went trouble shooting today. I ultimately decided to they replacing the sway bar end link because its a fairly quick and easy job. As I was dealing with that (and it turned out to be a big PAIN IN THE A#$) I discovered the upper ball joint was bad. This will.probably be the source of my noise. I'm still learning so its kind of a slow process!!
It could be a CV axle...They tend to make a popping noise but that could be your problem. Do you notice any play in the front when hitting bumps in the road or turning?
