replace passenger lower ball joint...now noise from drivers side??
I added a 2" level and shortly after my passenger lower ball joint went bad.I replaced the level with Bilstein 5100s. I also replaced the bad ball joint myself and there was no front end noise for about 2 weeks. Now I have a creek/grind on the drivers side. Could it be the other ball joint? I did the test where you raise the tire off the ground and use a pry bar to see if there's play in the joint. It doesn't look like there is. Any suggestions? Thanks
