Tranny Service
Tranny Service
Truck is at 95k right now. I will be doing 100k mile service soon obviously. I'm wondering what to do with the tranny. I understand not to do the flush due to the use of solvents and detergents but that's all the dealerships talk about. Or they say they drop and pan and change the filter. What exactly is the fluid exchange? I understand they pull the fluid from the dipstick through the whole system. Torque converter, cooler and pan. Once the fluid is pulled, is the pan dropped and the filter changed then new fluid pumped in? Where do I go with this?
-Curtis-
-Curtis-
Get a fluid exchange with a machine. It's the same machine they do a flush with, but it's used in the passive mode. It taps into the cooler lines and the exchange is done with the engine running, the internal pump is what moves the fluid. No pan drop. I'd take it to an independent shop or even a quick lube joint if the dealer insists on pumping their high-profit solvents through it.
I'm going to drop my pan, go have a fabricator install a drain plug in it, clean the magnet, change the screen, and re-install and pour the necessary quarts of Mercon V ATF. Then, in 15k - 20k miles i'll pull the plug, and replace what pours out. I'm too chicken to have any dealer or transmission shop service it, however I don't want to neglect it any longer.
