plugs done & cops still dont run good no power ??
Old Feb 8, 2013 | 08:10 PM
High Output's Avatar
still havnt done injectors will soon , but how do u know if its the cats, the miss isnt bad since the tune up but it still goes into limp mode when I kick it down & just doesnt have the power it should, & yes i cleaned the tb & sensors, has new fuel filter, ran sea foam thru brake line no change also, have not been back to shop to see if any codes r still up will do that soon , any other stuff to replace?
Old Feb 8, 2013 | 09:38 PM
Tailrace's Avatar
I'd have a shop check the cats, my buddy went through the same exact thing not too long ago....changed plugs, cops, cleaned the MAF and TB and still no power. Then it threw a code, one of the cats was completely done. He had them changed out and now it runs like a raped ape.
Old Feb 10, 2013 | 09:01 AM
Gordon M.'s Avatar
Check Fuel Pressure Too.
Old Feb 10, 2013 | 04:07 PM
ok here it is p2196 lack of heated oxygen sensor bank 1 & 2 probable cause
aa1 failed h02s11 bank 1 sensor
aa2 open or short circuit condition
aa3 leaking injector or fuel pressure regulator
aa4 maf sensor failure
number 5 cyl misfire still there
aa1 spark plugs
aa2 vaccum leak
aa3 injector fault
aa4high or low fuel pressure
thats where im at with latest comp update note that # 5 cyl has had 2 new motorcraft spark plugs injector although its from napa & a standard cop the other 7 cops r motorcraft plan on doing injectors this week as I stated before...
Old Feb 11, 2013 | 07:16 PM
well anybvody want to comment on next move ??
Old Feb 12, 2013 | 11:04 AM
What year and engine are we dealing with?
Old Feb 12, 2013 | 11:48 AM
jbrew's Avatar
Might want to post in the correct forum.
Old Feb 12, 2013 | 12:28 PM
94's dont have cops or OBD2 codes, so it's obviously something different than the truck in his profile.
Old Feb 12, 2013 | 03:45 PM
jbrew's Avatar
Unless it's a Frankenstein. Who knows ? I guess it at least has 5 cylinders.
Old Feb 12, 2013 | 05:10 PM
ITs a 2005 f-150 4x4 ext cab short box 5.4 3v automatic trans, xlt, 165,000 miles my profile is my old truck>>>>>>>
Old Feb 12, 2013 | 10:03 PM
I would suspect one or more leaky injectors. You are over miles for the Ford satisfaction program. Probably need front O2's too.
Old Feb 12, 2013 | 10:25 PM
jbrew's Avatar
Right, keep in mind, he let it suck from one of those nasty Sea Foam cans.. Directly!
That's most likely the absolute worst thing you can do to any engine w/O2's and converters, -let alone an 05.
Old Feb 12, 2013 | 10:41 PM
beechkid's Avatar
25 Year Member
Sounds like SF possibly damaged the cats, O2 sensors, etc.
Old Feb 13, 2013 | 06:05 PM
I did 1/3 of the can of sea foam, & this has been going on sense I bought the truck back in oct of 2012 so how did I hurt it , its been hurt , ok like I said before I will do injectors & front sensors planned on that any how, why am I geting a misfire yet on # 5 plug cop & injector is already done on that cyl???
Old Mar 5, 2013 | 07:37 PM
Ok I have plugs, cops, & just put all new motorcraft injectors in this last weekend, still no power & goes into limp mode when I hit the throttle, so like glc said I will do front 02 sensors this week & mas air flow there not to expensive, I am going to try to get to my brother inlaws shop to do a fuel pressure check, any more ideas thanks for all the help ..... I will add my next big project will be timming chain cause it does have the loose chain sound when warm idle , will this cause motor to run crappy ???
