2008 F-150 Front End Noise
My F-150 seems to have a loud "road noise" when driving straight or turning the wheel to the left. If I turn the wheel to the right, if smooths out. I have had it aligned and replaced the front tires. My mechanics at work jacked it up and looked for play in the front wheel bearings, but found none.
Any ideas what could be causing this?
Good chance its a wheel bearing since the noise goes away when turning right. As they said no freeplay dosent always mean your bearing is good or quiet. If you can jack it up again and look right at the outer edge of the wheel bearing from the the inside of your wheel, look for any differences in the gap all the way around the bearing or rust and flaking rust in or around the edge. Spin it around and listen for any noise. If its making much noise at all it will be a lot louder out on the road with the vehicles weight putting pressure on it.
