The rear trailer plugin does not work on my truck
To get power to the 7-pin, I think you need to install one relay in the fuse box next to the passenger's right foot.
I have set up two F-150s to tow, my 2000 and my 2008. For the 2000, I bought a kit that included the relay and brake controller wiring harness from etrailer.com. For the '08, the relay was in a plastic bag in the glove box. (The previous owner never towed anything.) Both trucks needed to have a relay installed for the 7-pin to work.
You'll find some good info and the parts you need here:
http://www.etrailer.com/Custom-Fit-V...dy/118242.html
I can post a scan of the factory instruction sheet that came with the '08's relay and harness on Monday if you need it.
Hi - help, can you describe where this relay is, mine is a 07 f150 5.4 4x4 i have checked every fuse and relay i can find, three fuse boxes under the hood every fuse and relay under the driver side dash. I know why my trailer socket stopped working (i shorted it out *******) i found the 20 amp that controls the turn and parking to the socket but the brake lights still don't work i am using a standard test light and an ohm meter to test the relays. I feel there must be a fuse,relay or fusible link that i can't find, also my truck cab third brake light died too.Thanks for any help
John
John
This is interesting. On my 2008 (with the tow package) the 7 pin (round) connector works just fine as it came from the dealer. The bag in the glovebox has a connector and pigtail for a brake controller should I decide to install one, but nothing regarding the trailer connectors. Up until this year I towed a boat with a 4 pin flat that fit the 4 pin flat connector on the truck, but this spring I bought a boat with disk brakes that required the 5 pin flat connector (for the reverse lockout solinoid). So I bought a 7 pin round to 5 pin flat adaptor and it works just fine in the 7 pin round outlet.
