150k miles and moving?
Been awhile since I've been on...
I'm moving from the sunshine state to tennessee. I won't have a shop that I can use up there like I do here. My little old pickup has 150k miles and still runs like a champ. I was trying to come up with some things I shoul do before I leave.
I'm thinking:
Brakes all the way around
Monroe quick struts up front
An allignment
Radiator flush
I think that's it.
I have already done plugs, cops, and cleaned the maf.
Anything else before I make the 800 mile trip?
Thanks folks.
I'm thinking:
An allignment
Radiator flush
I think that's it.
Thanks folks.
800 miles shouldnt be a big deal. I drive that much in two weeks and dont do anything except routine maintenance to my truck when needed.
You can check the brakes but it doesnt necessarily need them all the way around.
hes done his plugs already, and yes hes trying to get everything straight before beginning to sift through the shops in his new area to find a good one.
id do both diff fluids
trans filter and the 5 quarts it requires
struts/shocks
radiator flush with new motocraft coolant
brakes are easy enough any shop should be able to handle that task, i wouldnt worry too much about them
struts/shocks
Tranny rebilt 20k miles ago.
Never messed with the difs, I will add that to the list. Did the fuel filter prob 20k ago too, so I will add that on there. Thank you.
I'm moving to brentwood tn. I am going to work for the corp. Side of the busness. Its a trucking company/brokerage. The trck terminal is located here in florida... so I have a full shop whenever I need it.we just have an office up there.
I gotta add... I'm on my cell phon so typing is a bit tricky.
Monroe Quick Strut
Part No: 171362
Quick-Strut Complete Strut Assembly; 2 Wheel Drive; Front; Incl.NewSensa-TracStrut;ClSprg;BrngPlt;Insltr;Boot Kit;PN[AK63]MayBeReq.ToRplcOrig.LwrMntngBlt/Bshng
Warranty: LIMITED LIFETIME REPLACEMENT
$189.99
Add'l Discount: -$76.00$303.98
Moog Control Arm with Ball Joint
Part No: K80308
Frt Susp; Upper; RH; 1 Required
$123.99
Add'l Discount: -$24.80$99.19
Part No: K80306
Frt Susp; Upper; LH; 1 Required
$123.99
Moog Ball Joint
Part No: K80149
Frt Susp; Lower; 2 Required
$37.99
Add'l Discount: -$15.19$60.7
This puts me at $563 to my door. i would still need brakes, coolant, and a gew other small things. what do you think.
Part No: 171362
$189.99
Part No: K80308
$123.99
Part No: K80306
$123.99
Moog Ball Joint
Part No: K80149
$37.99
Monroe Quick Strut
Part No: 171362
$189.99
Part No: K80308
$123.99
Part No: K80306
$123.99
Moog Ball Joint
Part No: K80149
$37.99
Part No: 171362
$189.99
Part No: K80308
$123.99
Part No: K80306
$123.99
Moog Ball Joint
Part No: K80149
$37.99
I am going to leave the tranny alone, it was rebuilt not too long ago.
Added this to my list...
Wagner Brake Rotor
Part No: BD126116
Brake Rotor/Hub Assy.; RWD; w/o H/D Brake Payload Pkg.; Hub and Rotor Assy.
$182.99
Add'l Discount: -$73.19$292.79
Wagner ThermoQuiet® Brake Pads - Front
Part No: MX1083
Pads; ThermoQuiet; OE Replacement; OE Semi-Metallic; Incl. Inst. Hardware Kit
$52.99
Add'l Discount: -$10.60$42.39
Product Subtotal:$908.72Shipping Options Ground (3-4 days) - FREE 2 Day (1-2 days) - $155.93 Next Day - $162.35 Shipping Charges: Free Total Savings: ($227.18) Applied Promotion: P20
20% Off Your Order x Remove Enter Your Promo Code
If you have a promotion code, enter it here and click apply.
Total:$908.72(excludes applicable taxes and environmental fees)
puts me at 908.72. am i doing to much for a truck that has 150kmiles. i have no plans on getting rid of it. But is it worth it?
