stx to fx4 dash cluster
i found fx4 dash cluster for my stx for cheap. only problem is its in canada so its in km not miles! i hope this thing works. i dont really care that the the big numbers are in km and small little ones in red are miles- maybe i can get whiteface covers in miles and the sweep would be the same between the two gauges(most likely). i assume the odo will be in km. maybe i can switch this somehow or reprogrammed.
a tach would be great. something ive been missing for some time
As far as I know you CANNOT reprogram the cluster for the miles if the ODO is in KM. My opinion would to be to just look around and get one in Miles. Why would you go through all that trouble just to save a couple bucks when in the end it may not end up working in the first place, then your out the price of that one plus the cost of buying a new one in actual miles
But in the end the gauges look great! They go good with my silver STX.
-Matt
I think I paid around $200 for mine shipped, but that was a while ago! Good job! The install is easy. The hardest part is describing what you want programmed to the dealership.
-Matt
Edit: Here is my old post that might help: http://www.ford-trucks.com/forums/86...er-change.html
I forgot that it added "Theater-style" dome light fading!
-Matt
