OEM Trans Pan w/ Drain Plug
#46
#47
I just ordered the pan AGIAN! The first go around they "changed" the P/N based on my VIN and when I called to have them change it back to the one I wanted, they just canceled that line item on the order because I got everything else except the pan.![Roll Eyes (Sarcastic)](https://www.f150online.com/forums/images/smilies/rolleyes.gif)
I have re-ordered and left the VIN blank and added a statement to the comment section that this was a mod for the truck.![Wink](https://www.f150online.com/forums/images/smilies/wink.gif)
https://www.f150online.com/forums/20...over-cost.html
#49
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Well, here's one I fixed up for install in the near future. Used a 1" wide piece of steel, about 2-1/2" long and drilled / tapped a 1/2-20 NFT hole in center and two smaller 1/4-20 holes out beside it. Drilled three holes in pan in well at rear to match.
![](http://i220.photobucket.com/albums/dd22/CrystalPistolPics/CrystalPistolPics3%20Cars/Car%20Details/IM003646.jpg)
Put parts together with locktite on smaller bolts at final assymbly, and for good nmeasue piened threads slightly on end. The picture was with 1/4-20 bolts,, I went back and installed 1/4-20 button headed screws in their place.
![](http://i220.photobucket.com/albums/dd22/CrystalPistolPics/CrystalPistolPics3%20Cars/Car%20Details/IM003648.jpg)
Any 1/2-20 drain plug will work, no sealant needed between plate inside pan and pan as washer under head of plug will seal it.
![](http://i220.photobucket.com/albums/dd22/CrystalPistolPics/CrystalPistolPics3%20Cars/Car%20Details/IM003654.jpg)
Will reuse magnet that's already in the pan on the vehicle.
Later ........
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
