wiper cowl
Old Feb 16, 2011 | 10:19 PM
Dave0's Avatar
wiper cowl
hello. i did search for the issue with the drivers side wiper cowl popping up and rattling like crazy. some posted pics, but i couldnt see them for some reason. can someone post some new pics of where they put the screw to keep it down? the rattling is driving me crazy. thank you in advance
Old Feb 16, 2011 | 10:33 PM
quackrstackr's Avatar
I noticed just this weekend that mine has shrunk or something and no longer snaps together in the center. I messed with it for over a half an hour after taking it loose trying to get it to stay in the center. Every time that I got it together and put the christmas trees back in it, it would pop apart again.
Old Feb 16, 2011 | 11:10 PM
savagemonte's Avatar
I just took a self tapping screw and screwed the cowl to the cab, just underneath the hood.
If you look there is a flat spot where the cowl goes under the hood when its shut, so i screwed it down there, it still pops up a little towards the windshield, but i can live with that.
Old Feb 17, 2011 | 08:30 PM
Bryce Martinez's Avatar
glad to see im not the only one with this problem, i have yet to address it because i am going to paint them then figure it out
Old Feb 17, 2011 | 08:38 PM
sam1947's Avatar
Be sure to use a SS screw in order not to have to deal with a rust spot
Old Feb 18, 2011 | 09:47 AM
Dave0's Avatar
i understand under the hood, but where? id like to see pics of exactly where
Old Feb 18, 2011 | 04:39 PM
Glaffer's Avatar
Ford has a TSB out on this. 08-25-5, and 07-24-5
They're aware of this...
Old Feb 18, 2011 | 04:47 PM
Tsb?????
Old Feb 18, 2011 | 04:53 PM
Glaffer's Avatar
Technical Service Bulletin
The one for this addresses 2004 - 2008 F-150's and 2006-2008 Mark LT Pick-up's. It addresses Seating the Cowl Panel and Adjusting the Flange if necessary.
I have it in PDF but am not able to post it...
Old Feb 18, 2011 | 08:19 PM
Dave0's Avatar
from the searching that ive done, ive read that it is only a temporary fix to the problem. im looking for more of a permanent fix to this problem
Old Feb 18, 2011 | 08:22 PM
bogeyrider63's Avatar
i had mine done at the dealer per the tsb. only lasted for a year and now it has popped again.
Old Feb 18, 2011 | 08:46 PM
AmericanFlag's Avatar
What is the TSB number? I did a lookup and couldn't find anything on this.
Old Feb 18, 2011 | 11:19 PM
The guys that designed some of this stuff and spec'd out the plastics on these trucks need to be kicked square in the ball sacks.. and designing stuff out of plastic for the automotive and heavy duty industries is what I do for a living.
I thought that mine was fine until I had the windshield replaced a couple of weeks ago but now it won't stay together for love nor money. I don't know if the plastic had shrunk and the replacement was the final straw or if it was that way already and I just hadn't noticed it.
Old Feb 18, 2011 | 11:52 PM
Dave0's Avatar
https://www.f150online.com/forums/20...g-loose-2.html
Old Feb 19, 2011 | 03:04 PM
Dave0's Avatar
well i did the fix today, went on the highway, and no more drivers side wiper cowl popping up. win for me!!
