Windshield Cowl coming loose....
Originally Posted by the4by4freek
Mine did the same thing. My budies 04 did the same thing. I fixed both the exact same way and no problems. I got a stainless steel screw and installed it in the little channel right behind the hood weatherstripping. It is plastic to plastic. It hasn't moved in over 6 months. It used to move so bad that I could hear it in the truck!
If you open the hood and look at the cowl, you will see a peice of rubber weatherstripping that runs across it. Right in the center, there is a seam where the 2 sections go together. You might need a ladder for easier access to the cowl from the ground. I pulled the weather stripping back just a bit and got a #8x 1/2" stainless steel screw and installed it basically under the weatherstripping. The cowl sits on a plastic ledge and is held in place with little clips. When you look at it you will see exactly what I am talking about. I put the cowl back into position and put a screw in it right in the center. THe drivers side actually holds the passenger side into position, so if you catch the one side with a screw you'll be good to go.
I am sorry, a zip tie will not work. There is nowhere to put one. It is a flat area that meets to a flat area. The clips that are supposed to hold the two halves together leave much to be desired. I have still had zero problems with this fix.
So I drop by the hardware store and pick up the highly sought after #8 by 1/2" stainless steel screw. It cost me 9 cents. I bought a spare, just in case.
I went home, popped the hood, looked at the offending cowl, and said to myself, "It really can't be this simple!".
Well, folks, it is. All I did was follow the4by4freek's simple instructions and in less than a minute, seriously, less than a minute, my cowl problems were over.
And I tried to get the cowl to move around after the screw was in place. No chance. That sucker is in there good.
Now, all we have to do is package this "mod" up, slap some glossy full color instructions in along with a celebrity endorsement and we can sell these for $14.95, at least.
(Sorry for the crappy picture.)
